External UART expansion headers
The MitySOM-335x Development Kit has two general purpose UART headers that allow for the connection of either RS232 or RS485/422 expansion boards. One of each expansion board is included with a development kit.
Linux Serial Port TTY Mapping
Expansion Port 0 - J506 = /dev/ttyO4 = GPIO 84 for TX enable
Expansion Port 1 - J505 = /dev/ttyO3 = GPIO 105 for TX Enable
You can use an application such as minicom or microcom for testing the serial communications before it is utilized in a custom application.
Serial Port TX Enable Control
Each of the expansion UART headers has a TX enable line for use with the RS485/422 (the RS232 does not use the line) expansion board. If you kernel is currently not configured to control the enable line itself then you will need to manually toggle this control line.
Example using J506
To Transmit from RS485:
echo "84" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio84/direction
echo "1" > /sys/class/gpio/gpio84/value
microcom -s 115200 /dev/ttyO4
To Receive from RS485:
echo "0" > /sys/class/gpio/gpio84/value
RS-232 Module pinout
The RS-232 module [ 80-000450RI-1] is configured as a DTE device, with tx on pin 3, rx on pin 2. If you are connecting to a typical PC serial port, you will need a NULL modem cable or adapter.
