- USB WiFi Configuration
- RALink Based USB WiFi
- Atheros Based USB WiFi
- Configure Linux to Use and Connect to WiFi Network
- USB WiFi Throughput Test Results
- Helpful Webpages
USB WiFi Configuration¶
Commercial Temperature Rated Adapters¶
Currently we have verified the following USB WiFi adapters:
Brand | Model | Wireless Chipset | Chipset Brand | Kernel Version | USB Port | SoM | Verified/Tested | Temp Range |
TPLink | TL-WN722N | AR9271 | Atheros | 3.2.0 | 1.1 & 2.0 | L138F | Yes | 0C to 40C |
Netgear | WNA1100 | AR9271 | Atheros | 3.2.0 | 2.0 | L138F | Yes | 0C to 40C |
TPLink | TL-WN422G V2 | AR9271 | Atheros | N/A | N/A | N/A | No | 0C to 40C |
TPLink | TL-WN727N | RT2870sta | RALink | 3.2.0 | 2.0 | L138F | Yes | 0C to 40C |
Industrial Temperature Rated Adapters¶
Embedded Works | EW7220UB | AR9271 | Atheros | 3.2.0 | 2.0 | L138F | Yes | -40C to +85C |
N/A | WUBA-171GN | AR9271 | Atheros | N/A | N/A | N/A | No | -30C to +75C |
RALink Based USB WiFi¶
Details on support offered by the RT2800 (RT2870) chipset:
http://linuxwireless.org/en/users/Drivers/rt2800usb
List of supported USB devices based upon the RALink Chipset:
http://linuxwireless.org/en/users/Drivers/rt2800usb/devices
RALink Kernel and Configuration Changes:¶
1) Verify that you are currently working with a 3.2.0 kernel version
"git branch"
- "cd /home/mitydsp/projects/linux-davinci/"
- "make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- menuconfig"
3) To build in support for the RALink devices you need to enable the ATH9K device drivers.
Go into the following menu(s):- Device Drivers -> Generic Driver Options
- Select "*" Userspace firmware loading support
- Networking Support -> Wireless
- Select "*" cfg80211
- Select "*" cfg80211 wireless extensions
- Select "*" Wireless extensions sysfs files
- Select "*" Common routines for IEEE802.11 drivers
- Select "*" Generic IEEE 802.11 Networking Stack (mac80211)
- Select "*" Minstrel
- Select "*" Minstrel 802.11n support
- Select "*" Enable LED triggers
- Device Drivers -> Network Device Support -> Wireless LAN
- Select "*" Ralink driver support
- Go into "Ralink driver support"
- Select "*" Ralink rt2500 (USB) support
- Select "*" Ralink rt2501/rt73 (USB) support support
- Select "*" Ralink rt27xx/rt28xx/rt30xx (USB) support
- Select "*" rt2800usb - Include support for rt33xx devices
- Select "*" rt2800usb - Include support for rt35xx devices (EXPERIMEN
- Select "*" rt2800usb - Include support for rt53xx devices (EXPERIMEN
- Select "*"rt2800usb - Include support for unknown (USB) devices
4) Exit out of Menu Config and save the new configuration when prompted
5) Now you need to rebuild the kernel with the new configuration- "make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- uImage"
6) Once complete a new uImage will be created and placed in the /arch/arm/boot/ directory. Load your SoM with this kernel.
Root File System¶
You need to be using the Root File system for the 3.2.0 kernel. The "mityomap-base" file system is fine. See the following wiki for information on loading your file system.
http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Linux_Root_File_System
Please copy the included rt2870.bin file into the /lib/firmware/ directory (make the dir if necessary). Depending on the RALink device a different driver/firmware may be needed.
Atheros Based USB WiFi¶
Details on support offered by the Ath9k (AR9271) chipset:
http://linuxwireless.org/en/users/Drivers/ath9k_htc
List of supported USB devices based upon the Atheros Chipset:
http://linuxwireless.org/en/users/Drivers/ath9k_htc/devices
Atheros Kernel and Configuration Changes:¶
"git branch"
3) To build in support for the Atheros devices you need to enable the ATH9K device drivers.
Symbol: ATH9K [=y] Type : tristate Prompt: Atheros 802.11n wireless cards support Defined at drivers/net/wireless/ath/ath9k/Kconfig:6 Depends on: NETDEVICES [=y] && WLAN [=y] && ATH_COMMON [=y] && \ MAC80211 [=y]Go into the following menu(s):
- Select "*" Atheros Wireless Cards
- Go into "Atheros Wireless Cards"
- Select "*" Atheros 802.11n wireless cards support
- Select "*" Atheros ath9k AHB bus support
- Select "*" Atheros ath9k rate control
- Select "*" Atheros HTC based wireless cards support
- Select "*" Linux Community AR9170 802.11n USB support
- Select "*" SoftLED support
Root File System¶
Please copy the included htc_9271.fw file into the /lib/firmware/ directory (make it if necessary).
Configure Linux to Use and Connect to WiFi Network¶
Install necessary tools¶
I have found the following tools to be necessary to get the WiFi working.
- WPA_Supplicant (opkg install wpa-supplicant)
- wireless-tools (opkg install wireless-tools)
Configure WPA Supplicant¶
NOTE: Wireless Tools (iwconfig) ONLY supports open or WEP encrypted connections
First you will need to edit /etc/WPA_supplicant.conf. By default this file contains a lot of useful information about how to configure a WiFi connection in this file. Please mv this file to something such as WPA_Supplicant_Orig.Conf for reference.
1) Create a new /etc/WPA_Supplicant.conf that is blank
2) Enter the following lines at the top, these are general configuration lines
ctrl_interface=/var/run/wpa_supplicant ctrl_interface_group=0 eapol_version=1 ap_scan=2 fast_reauth=1
3) Now you need to enter information about the specific network you want to connect to. The example below will setup a single connection to a WPA-PSK (TKIP) access point.
# Example of WPA network network={ ssid="your_ssid" proto=WPA key_mgmt=WPA-PSK pairwise=TKIP group=TKIP psk="ascii_passphrase" } # Example of a WPA2 network network={ ssid="your_ssid" scan_ssid=1 proto=RSN key_mgmt=WPA-PSK pairwise=CCMP TKIP psk="ascii_passphrase" } # Example of an open network network={ ssid="your_ssid" key_mgmt=NONE }
4) Save the new/changes to WPA_Supplicant.conf
Deemed Not Necessary: At this point using the wpa_cli front end application for WPA-Supplicant landed me with the following error "Could not connect to wpa_supplicant - re-trying". I found that I may need to make the following changes to the following files:
/usr/share/dbus-1/system-services/fi.epitest.hostap.WPASupplicant.service /usr/share/dbus-1/system-services/fi.w1.wpa_supplicant1.service Change the "Exec=" line to be "Exec=/usr/sbin/wpa_supplicant -u -s -O /var/run/wpa_supplicant" in both files.
Configure /etc/network/interfaces file¶
Make sure the following entry exists:
# Wireless interfaces auto wlan0 iface wlan0 inet dhcp wireless_mode managed wireless_essid any wpa-driver wext wpa-conf /etc/wpa_supplicant.conf
I believe the wireless_mode and wireless_essid lines should be commented out but am not sure at this time.
Connecting to your Access Point¶
At this point everything should be configured to support the USB WiFi adapter.
1) Insert the USB WiFi adapter into the USB port
2) You should messages similar to below:
If you only see the first line than you most likely did not build in the necessary kernel components from menuconfig.
If you receive an error about the firmware file you need to create the /lib/firmware/ directory and place it there.
3) Verify that there is a "ifconfig -a" entry for wlan0 but not "ifconfig"
4) Perform a "ifup wlan0" command which will bring up the wireless. Most likely the DHCP will FAIL, we will address this shortly.
5) Verify that there is a "ifconfig" entry for wlan0
6) Execute the "wpa_cli" application. It should state "Selected interface 'wlan0'" when it is started. You will now have a > prompt. At this prompt enter "status"
A) If there is an entry for "wpa_state=COMPLETED" than the WiFi is connected to the access point. If there is NOT an "ip_address=XXX.XXX.XXX.XXX" entry than dhcp failed and needs to be redone, #8 below.
B) If there is only a "wpa_state=DISCONNECTED" you need to enter the following command "reassociate"
C) If the state is "wpa_state=ASSOCIATING" and you keep seeing messages printed baout Association failed perform a "disconnect" and then "reassociate"
D) If the entry has something similar to the following (COMPLETED, with IP Address and proper SSID etc) then the wireless is working.
bssid=00:24:b2:56:cd:3c ssid=thinklink id=0 mode=station pairwise_cipher=TKIP group_cipher=TKIP key_mgmt=WPA-PSK wpa_state=COMPLETED ip_address=10.0.102.39
7) kill the "wpa_cli" application
8) If the wifi needs to acquire a DHCP address enter the following command from your linux prompt
"/sbin/udhcpc -iwlan0"
If everything works output similar to below will be shown
udhcpc (v1.19.3) started Sending discover... Sending select for 10.0.102.39... Lease of 10.0.102.39 obtained, lease time 7200 adding dns 10.0.0.1 adding dns 24.92.226.12 adding dns 24.92.226.11 adding dns 8.8.8.8 adding dns 8.8.4.4
9) Perform a ping test to verify that your wireless is working.
Helpful commands¶
- The "iwconfig" command will shows you connection status as well as signal strength
lo no wireless extensions. wlan0 IEEE 802.11bgn ESSID:"thinklink" Mode:Managed Frequency:2.462 GHz Access Point: 00:24:B2:56:CD:3C Bit Rate=2 Mb/s Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=59/70 Signal level=-51 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:91 Missed beacon:0 eth0 no wireless extensions. can0 no wireless extensions.
- The "wpa_cli status" command displays what Access Point you are connected to (if any) and the IP address that you were given
Selected interface 'wlan0' bssid=00:24:b2:56:cd:3c ssid=thinklink id=0 mode=station pairwise_cipher=TKIP group_cipher=TKIP key_mgmt=WPA-PSK wpa_state=COMPLETED ip_address=10.0.102.39
- The "iwlist wlan0 scan" command lists all detected wifi access points
Cell 07 - Address: 00:24:B2:56:CD:3C Channel:6 Frequency:2.437 GHz (Channel 6) Quality=56/70 Signal level=-54 dBm Encryption key:on ESSID:"thinklink" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s 9 Mb/s; 12 Mb/s; 18 Mb/s Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s Mode:Master Extra:tsf=0000000014db0617 Extra: Last beacon: 410ms ago IE: Unknown: 00097468696E6B6C696E6B IE: Unknown: 010882848B960C121824 IE: Unknown: 030106 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK
USB WiFi Throughput Test Results¶
The following wiki page will document some testing performed to determine throughput of the USB WiFi adapters used with a MityDSP-L138 SoM.
ARM9 USB WiFi Results
Helpful Webpages¶
http://ebixio.com/blog/2011/09/15/how-to-make-wpa_cli-talk-to-wpa_supplicant-in-ubuntu/
http://www.thinkwiki.org/wiki/How_to_install_wpa_supplicant
http://cboard.cprogramming.com/networking-device-communication/118431-connect-wireless-network-via-linux-command-line.html
http://linux.die.net/man/5/wpa_supplicant.conf
http://www.digipedia.pl/man/doc/view/udhcpc.8/
