Setting up MityDSP-L138 for Hello World program
Added by Artem Khotab about 7 years ago
Good day,
I'm trying to set up the “DSP Hello World” from the Wiki instructions (https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/DSP_Hello_World). “Compiling for the ARM” was ommited, as the main goal is to run “Hello World” on DSP. Following the instruction step by step I get an error, when try to specify the MDK location with Platform.tci file:
js: "C:/ti/bios_5_42_01_09/xdctools/include/utils.tci", line 976: Error: Can't find Platform.tc[ip] file for 'criticallink.platforms.MityDSP-L138'
Correct any script errors in D:/Folder/MY_Project/CCS_PROECT/.metadata/.plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS/.gconf/HelloWorldDSP/HelloWorldDSP/HelloWorldDSP.tcf
using the Configuration Tool or a text editor, if necessary.
TConf initialization arguments:
-e environment['config.importPath']='D:/Folder/MY_Project/CCS_PROECT/HelloWorldDSP;C:/ti/bios_5_42_01_09/packages' -e environment['config.scriptName']='HelloWorldDSP.tcf'
Probably the solution is obvious, but please, help me.
Regards.
Replies (4)
RE: Setting up MityDSP-L138 for Hello World program - Added by Jonathan Cormier about 7 years ago
Hi Artem,
What version of Code composer are you using? Also what MDK version?
RE: Setting up MityDSP-L138 for Hello World program - Added by Artem Khotab about 7 years ago
Hi Jonathan,
I use CCS v.6.1.0 and MDK of 2014 year.
Code Composer is very finicky about exact paths for the Platform.tci file. It's possible you went too many, or too few directories in when specify this information under Properties->Build->TCONF->General Options or when creating the DSP/BIOS configuration file.
Hi Jonathan,
I thought so. Ok, I'll try to do somthing with it.
Thank you for help.
