kernel panic on virtual machine start
Added by Vivek Ponnani over 5 years ago
I had setup of virtual machine with Critical_Link_Unified_VM_14-04_04-2017.ova image. Something went wrong with sudo tar xzvf command in root directory. After that VM stop responding. I powered off virtual machine. When I tried to restart the VM, there is an error end kernel panic- not syncing. Attaching screen shot for the same.I wanted to get back the folders and data I had in virtual machine. Is there any method to get back the data? I tried some software to extract files from .vmdk file which in virtual machine folder, but it didn't work out. Please suggest for recovery of data.
Vivek ponnani.
Replies (4)
RE: kernel panic on virtual machine start - Added by Tim Iskander over 5 years ago
Vivek
Your best bet is the following:
Rename the existing VM
Re-import the VM from the ova image
Go in to settings for the newly imported VM and add your existing VM disk image to the new VM
mount the old VM image in your new VM as /mnt (or what ever you choose)
copy the files you want from the old image to the new
You can then remove the old disk from the new VM
RE: kernel panic on virtual machine start - Added by Vivek Ponnani over 5 years ago
Thanks Tim for your reply. As per your suggestion it seems I must have VM setup where it failed. But unfortunately, I did backup for .vmdk file only for my old VM setup.
I already installed new VM setup with ova image and now want to read from old .vmdk file. Is it possible?
Vivek
Hello Tim,
I also tried to add hard disk option in new VM for old .vmdk file . Then I tried to mount that in VM. below is the process.
mitydsp@vagrantup:~$ sudo fdisk -l
[sudo] password for mitydsp:
Disk /dev/sda: 128.8 GB, 128849018880 bytes
255 heads, 63 sectors/track, 15665 cylinders, total 251658240 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000ad2d4
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 499711 248832 83 Linux
/dev/sda2 501758 251656191 125577217 5 Extended
/dev/sda5 501760 251656191 125577216 8e Linux LVM
Disk /dev/sdb: 128.8 GB, 128849018880 bytes
/dev/sdb1 * 2048 499711 248832 83 Linux
/dev/sdb2 501758 251656191 125577217 5 Extended
/dev/sdb5 501760 251656191 125577216 8e Linux LVM
Disk /dev/mapper/vagrantup--vg-root: 127.0 GB, 127016108032 bytes
255 heads, 63 sectors/track, 15442 cylinders, total 248078336 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/vagrantup--vg-root doesn't contain a valid partition table
Disk /dev/mapper/vagrantup--vg-swap_1: 1572 MB, 1572864000 bytes
255 heads, 63 sectors/track, 191 cylinders, total 3072000 sectors
Disk /dev/mapper/vagrantup--vg-swap_1 doesn't contain a valid partition table
mitydsp@vagrantup:~$ ls/mnt
bash: ls/mnt: No such file or directory
mitydsp@vagrantup:~$ sudo mount /dev/sdb1 /mnt
mitydsp@vagrantup:~$ ls /mnt
abi-4.2.0-27-generic memtest86+.bin
config-4.2.0-27-generic memtest86+.elf
grub memtest86+_multiboot.bin
initrd.img-4.2.0-27-generic System.map-4.2.0-27-generic
lost+found vmlinuz-4.2.0-27-generic
Now, how can I get the files from this. Please explain. Is anything I am missing?
Vivek.
I'm afraid the answer is probably to create a new ubuntu VM from scratch and then (after removing the image from any other VMs) add the vmdk image to it.
The problem with the approach I gave you is that the system is using LVM and the UUIDs of the LVM components are the same (as it is a clone).
If you create a new virtual machine (don't bother using LVM on it) and then add your existing disk to it any UUIDs present will be diffrent.
It might be a good idea to use VirtualBox's snapshot feature and take a snapshot of your machine as a sort of backup for cases like this.
cheers
/Tim
