MityDSP-L138 OpenEmbedded overlay
The MityDSP-L138 Open Embedded overlay is a directory structure needed to build a full root filesystem, the SDK, or set of installation packages from the ground up. Normally, users do not need to use this file unless they are required to perform the following operations:
  • Rebuild the SDK using a different release of GCC
  • Rebuild binaries / utilities in the Root Filesystem using a different compiler than the one provided in the MityDSP SDK.
  • Target a different release level of the Open Embedded / Angstrom distribution
  • Target a different release level of utilities used within the Angstrom distribution
  • Add additional packages to the base root filesystem (there are other means to accomplish this, see using the opkg utility)
See Installing Open Embedded for details.
Releases
