Initial Bringup
Build firmware
Instructions based on Intel's: https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderForAgilex5
All these commands expect you to work out of the same top level directory. For example: ~/projects/agelix-5/firmware
export TOP_FOLDER=`pwd`
Install dependencies
Intel ran this on Ubuntu 20.02
sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath \
socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping \
python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev pylint3 xterm python3-subunit \
mesa-common-dev zstd liblz4-tool
Fetching the ARM Tool chain
cd $TOP_FOLDER
wget https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
tar xf gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
Set your env to use the toolchain
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
export ARCH=arm64
export CROSS_COMPILE=aarch64-none-linux-gnu-
Building the ARM Trusted Firmware
NOTE: Please apply the following patch to switch the console to UART1: https://support.criticallink.com/redmine/attachments/34881
cd $TOP_FOLDER
rm -rf arm-trusted-firmware
git clone -b socfpga_agilex5-ES_RC https://github.com/altera-opensource/arm-trusted-firmware arm-trusted-firmware
cd arm-trusted-firmware
git apply commit-dadfc1a
make -j 48 PLAT=agilex5 bl31
cd ..
Output: $TOP_FOLDER/arm-trusted-firmware/build/agilex5/release/bl31.bin (to used for u-boot.itb generation)
Building U-Boot
cd $TOP_FOLDER
rm -rf u-boot-socfpga
git clone -b socfpga_agilex5-ES_RC https://git.criticallink.com/git/u-boot-socfpga.git
cd u-boot-socfpga
make mrproper
make socfpga_agilex5_defconfig
# link to ATF
ln -s ../arm-trusted-firmware/build/agilex5/release/bl31.bin
make -j 48
aarch64-none-linux-gnu-objcopy  -I binary -O ihex --change-addresses 0x0 spl/u-boot-spl-dtb.bin spl/u-boot-spl.ihex
Building FPGA Project
Build the FPGA project as usual, qsys top level is called mitysbc_a5e.qsys. Build with Quartus 23.4.
Build the HPS SOF
Required:
  • U-Boot is already built
  • FPGA project is already built
  • Copy the $TOP_FOLDER/u-boot-socfpga/spl/u-boot-spl.ihex into your top level FPGA project
    quartus_pfg -c output_files/mitysbc_a5e.sof mitysbc_a5e_hps.sof -o hps_path=u-boot-spl.ihex
Output: mitysbc_a5e_hps.sof
Building The kernel
cd $TOP_FOLDER
rm -rf linux-socfpga
git clone -b socfpga_agilex5-ES_RC https://git.criticallink.com/git/linux-socfpga.git linux-socfpga
cd linux-socfpga
make defconfig
make -j 48 Image && make intel/socfpga_agilex5_socdk.dtb
Building Yocto
cd $TOP_FOLDER
rm -rf yocto && mkdir yocto && cd yocto
git clone -b nanbield https://git.yoctoproject.org/poky
git clone -b socfpga_agilex5-ES_RC https://git.yoctoproject.org/meta-intel-fpga
git clone -b nanbield https://github.com/openembedded/meta-openembedded
source poky/oe-init-build-env ./build
echo 'BBLAYERS += " ${TOPDIR}/../meta-intel-fpga "' >> conf/bblayers.conf
echo 'BBLAYERS += " ${TOPDIR}/../meta-openembedded/meta-oe "' >> conf/bblayers.conf
echo 'BBLAYERS += " ${TOPDIR}/../meta-openembedded/meta-networking "' >> conf/bblayers.conf
echo 'MACHINE = "agilex5"' >> conf/local.conf
echo 'KERNEL_PROVIDER="linux-socfpga-lts"' >> conf/local.conf
echo 'EXTRA_IMAGE_FEATURES += " package-management "' >> conf/local.conf
echo 'CORE_IMAGE_EXTRA_INSTALL += " iperf3 phytool i2c-tools"' >> conf/local.conf
echo "KBRANCH = \"socfpga_agilex5-ES_RC\"" >> conf/site.conf
echo "UBOOT_BRANCH = \"socfpga_agilex5-ES_RC\"" >> conf/site.conf
echo "ATF_BRANCH = \"socfpga_agilex5-ES_RC\"" >> conf/site.conf
bitbake core-image-minimal
Make SD Card
Followed Intel's instructions but needed to make rootfs bigger because I used the full-cmdline rootfs so run the following instead at the end.
sudo python3 make_sdimage_p3.py -f -P fatfs/*,num=1,format=fat32,size=53M -P rootfs/*,num=2,format=ext3,size=512M -s 1024M -n sdcard.img
Booting the Board
  1. Make sure the USB cable is connected to J21 for the UART console, baud rate should be 115200
  2. Make sure the SD is in and the jumper J20 is on the 2 pins closest to the SOC
  3. Program the FPGA with mitysbc_a5e_hps.sof over JTAG
  4. When the board gets to the u-boot prompt enter the following to boot linux
    fatload mmc 0:1 82000000 Image
    fatload mmc 0:1 86000000 socfpga_agilex5_socdk.dtb
    setenv bootargs console=ttyS0,115200 root=${mmcroot} rw rootwait;
    booti 0x82000000 - 0x86000000
