Programming the DevKit Skyworks PLL¶
MitySOM-A5E Standard Development Kit¶
The MitySOM-A5E Standard Development Kit carrier card includes an SI5332A-D-GM3 12 channel Phase Lock Loop clock generation chip.
The PLL chip is provided a (coherent) copy of the 25 MHz reference clock sourced by the MitySOM-A5E Standard. This same clock is also fed back to the SOM on an HPS IO pin to support clocking the HPS and it's PLLs. The PLL chip is powered with 1.8V and uses 1.8V on the I2C control port.
The PLL chip is not pre-programmed on the carrier card. The PLL chip should be programmed using the I2C interface. Several, including the base, reference projects include a uBoot script ("config_pll.scr") that will program and enable the output clocks according to the table below:
| PLL Ref Des | I2C_EMAC1_SDA Address | Clock Index | Frequency | Standard | Connection | Notes |
| U68 | 0x6A | 0 | 150 MHz | HCSL | REFCLK_GTSR4A_RX_P/N | For Display Port |
| U68 | 0x6A | 1 | N/A | Disabled | REFCLK_GTSR4C_CH1_P/N | Can be enabled for FMC GTS clocking |
| U68 | 0x6A | 2 | 156.25 MHz | HCSL | REFCLK_GTSL1C_CH1_P/N | To Support SFP+ operation |
| U68 | 0x6A | 3 | N/A | Disabled | REFCLK_GTSL1B_RX_P/N | Spare |
| U68 | 0x6A | 4 | N/A | Disabled | REFCLK_GTSR4B_RX_P/N | Can be enabled for FMC GTS clocking |
| U68 | 0x6A | 5 | 100 MHz | HCSL | REFCLK_GTSL1C_RX_P/N | To support USB3, M.2 M-key and M.2 E-key PCIe |
| U68 | 0x6A | 6 | 125 MHz | LVDS | HSIO | To support MIPI reference clocks |
| U68 | 0x6A | 7 | 125 MHz | LVDS | HSIO | To support MIPI reference clocks |
| U68 | 0x6A | 8 | 125 MHz | LVDS | HSIO | To support SGMII reference clock |
| U68 | 0x6A | 9 | N/A | Disabled | HSIO | To support SGMII reference clock |
| U68 | 0x6A | 10 | 100 MHz | HCSL | m.2 M-Key Connector | Reference Clock for m.2 M-key interface |
| U68 | 0x6A | 11 | 100 MHz | HCSL | m.2 E-Key Connector | Reference Clock for m.2 E-key interface |
Altering the PLL configuration¶
Users may create their own uBoot scripts to change the configuration of the PLL chip. The chip configuration files can be build using the Skyworks ClockBuilder Pro application. The application can be used to generate output programming files as well as a CSV file containing the necessary register settings.
The linux script on this page, pgm-pll-uboot.sh , can be used to convert the generated CSV file into a set of uBoot commands for programming the PLL.
MitySOM-A5E Mini Development Kit¶
The MitySOM-A5E Mini development kit carrier card includes a si5338 4 channel (differential) Phase Lock Loop Chip.
The PLL chip is provided a (coherent) copy of the 25 MHz reference clock sourced by the MitySOM-A5E Mini. This same clock is also fed back to the SOM on an HPS IO pin to support clocking the HPS and it's PLLs. The PLL chip is powered with 1.8V and uses 1.8V on the I2C control port.
The default PLL configuration for the revision 1 carrier board is as follows:
| PLL Ref Des | I2C1 Address | Clock Index | Frequency (MHz) | Standard | Connection | Notes |
| U10 | 0x70 | 0 | 156.25 | LVDS (AC) | FPGA REFCLK_GTSL1B_RX (BA66/BA69) | Intended for SFP+ Port |
| U10 | 0x70 | 1 | 150 | LVDS (AC) | FPGA REFCLK_GTSL1C_RX (AU66/AU69) | Intended for Display Port |
| U10 | 0x70 | 2 | 100 | LVDS (AC) | FPGA REFCLK_GTSL1C_CH1 (AR66/AR69) | Spare |
| U10 | 0x70 | 3 | 20 | LVDS (DC) | FPGA DIFF_IO_3A_T19 (P22/V22) | Intended for MIPI or LVDS |
The default PLL configuration for the revision 2 carrier board is as follows:
| U10 | 0x70 | 0 | 150 | HCSL (AC) | FPGA REFCLK_GTSL1B_RX (BA66/BA69) | Intended for Display Port |
| U10 | 0x70 | 1 | 156.25 | HCSL (AC) | FPGA REFCLK_GTSL1C_RX (AU66/AU69) | Intended for SFP+ Port |
| U10 | 0x70 | 2 | 100 | HCSL (AC) | FPGA REFCLK_GTSL1C_CH1 (AR66/AR69) | Intended for USB 3.0 |
| U10 | 0x70 | 3 | 20 | LVDS (DC) | FPGA DIFF_IO_3A_T18 (K21/K24) | Intended for MIPI or LVDS |
The root filesystem includes a perl script developed by Intel in /usr/bin/si5338_cfg that may be used to program the SI5338 device from the HPS should an alternate clocking scheme be needed.
In addition, there is a fixed 100 MHz HCSL clock driver feeding FPGA REFCLK_GTSR4C_RX (AY17/AY19) in order to support the PCIe interface.
