Building Root Filesystem 18.1¶
 - Building Root Filesystem 18.1
This guide covers the creation of the Critical Link provided Linux filesystem and SDK installation script for the MitySOM-5CSx Dev Kit.
Overview¶
If you are interested in building or maintaining your own Linux distribution from source for the MitySOM-5CSx family, there is a Yocto compatible meta layer for the module provided at https://support.criticallink.com/gitweb/?p=meta-cl-socfpga.git;a=summary.
The current branch of the Critical Link SOCFPGA is: Rocko
The recommended operating system for the build machine: Ubuntu 18.04
Pre-built Rocko toolchain: poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-toolchain-2.4.4.sh
Note: Yocto can use around 50GB of space on the host machine.
Prerequisites¶
Packages¶
- It is recommended that you use Ubuntu 18.04 with the following packages installed:
Docker¶
docker pull crops/poky:ubuntu-18.04
Setting up Yocto¶
Yocto is made up of multiple meta layers, these layers are stored in Git repositories. To get everything setup to build, these repositories will need to be cloned and a few config files will need to be copied over.
- Change into your local projects directory and clone the needed repositories.
git clone -b rocko git://git.yoctoproject.org/poky cd poky git clone -b rocko git://git.openembedded.org/meta-openembedded git clone -b rocko git://git.yoctoproject.org/meta-ti git clone -b rocko git://support.criticallink.com/home/git/meta-cl-socfpga.git
 - Launch the docker container interactively:
docker run --rm -it -v `pwd`:/work --workdir=/work --tmpfs /opt/poky crops/poky:ubuntu-18.04 /bin/bash
 - Source the Yocto environment. Note: The current directory will change from poky to poky/build.
. ./oe-init-build-env
 - Copy Critical Link's example configuration files into build/conf.
cp ../meta-cl-socfpga/conf/bblayers.conf.sample conf/bblayers.conf cp ../meta-cl-socfpga/conf/local.conf.5cs conf/local.conf
Building the filesystem¶
The following steps will build the filesystem used in the MitySOM-5CSx Dev Kit.
- Open a terminal and change into the poky directory.
 - Source the yocto environment. Note: The current directory will change from poky to poky/build.
 - Build the filesystem. Note: This will take a while. Typing CTRL+C at any point during the process will cause the process to finish its current tasks and exit. Running the command again will allow the process to continue from where it was stopped.
bitbake mitysom-image-base
 - The tarball of the filesystem can be found at tmp/deploy/images/mitysom-c5/mitysom-image-base-mitysom-c5.tar.gz.
Building the SDK installation script¶
The following steps will build the SDK installation script with the cross-compiler toolchain used in the MitySOM-5CSx Dev Kit.
 - Build the SDK installation script. Note: This will take a while. Typing CTRL+C at any point during the process will cause the process to finish its current tasks and exit. Running the command again will allow the process to continue from where it was stopped.
 - The SDK installation script can be found at tmp/deploy/sdk/poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-toolchain-2.4.4.sh.
Changes from the Dora branch¶
The new meta-cl-socfpga layer was based off of the meta-mitysom-5csx layer. The name change is because the layer now also supports Critical Links' MitySOM-A10S, which uses the Intel Arria 10 SoC.
The notable changes to the layer are as follows:- Addition of the 4.9.78-ltsi kernel, which is the default now for the MitySOM-5CSx.
 - Change to build the kernel as a zImage instead of uImage.
Steps to switch back to older kernel format¶
It is still possible to configure the Rocko branch to build the 3.16 kernel and uImage. To do so, follow the above instructions for setting Yocto but after copying over the example local.conf, edit it and add the followings lines:
KERNEL_IMAGETYPE = "uImage"
UBOOT_ENTRYPOINT = "0x00008000"
KERNEL_EXTRA_ARGS += "LOADADDR=${UBOOT_ENTRYPOINT}"
LINUX_VERSION_SUFFIX = ""
LINUX_VERSION = "3.16"
KBRANCH = "socfpga-3.16"
Related Articles¶
