Ethernet Throughput¶
Critical Link has performed multiple throughput tests of the RGMII based Ethernet interface from the MitySOM-5CSx family of modules. The testing below has been performed using the Critical Link MitySOM-5CSx development board (80-000578) which features a Micrel KSZ9031 Gigabit Ethernet phy.
As with any Ethernet phy implementation the layout of the phy signals must be done properly otherwise degraded performance can occur. Please feel free to contact your Critical Link representative for design recommendations.
Sample TCP iperf version 2 test with MitySOM-5CSX (5CSX-H6-42A-RC) Baseboard as Client¶
root@socfpga_cyclone5:~# iperf -c 10.0.0.114 -t 30 -i 5 ------------------------------------------------------------ Client connecting to 10.0.0.114, TCP port 5001 TCP window size: 20.7 KByte (default) ------------------------------------------------------------ [ 3] local 10.0.20.80 port 37251 connected with 10.0.0.114 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0- 5.0 sec 285 MBytes 478 Mbits/sec [ 3] 5.0-10.0 sec 285 MBytes 478 Mbits/sec [ 3] 10.0-15.0 sec 285 MBytes 478 Mbits/sec [ 3] 15.0-20.0 sec 285 MBytes 478 Mbits/sec [ 3] 20.0-25.0 sec 285 MBytes 478 Mbits/sec [ 3] 25.0-30.0 sec 285 MBytes 479 Mbits/sec [ 3] 0.0-30.0 sec 1.67 GBytes 478 Mbits/sec
Sample TCP iperf version 2 test with MitySOM-5CSX (5CSX-H6-42A-RC) Baseboard as Server¶
root@socfpga_cyclone5:~# iperf -s ------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 85.3 KByte (default) ------------------------------------------------------------ [ 4] local 10.0.20.80 port 5001 connected with 10.0.0.114 port 58510 [ ID] Interval Transfer Bandwidth [ 4] 0.0-30.0 sec 2.55 GBytes 730 Mbits/sec
Measured "Gigabit" performance using MitySOM 5CSX-H6-42A-RC module on 5CSx Development Kit Board¶
stmmaceth ff702000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
TCP¶
iperf version 3
TCP OUT (client): 666 MBits/sec TCP IN (server): 810 MBits/sec
iperf version 2.0.4 (7 Apr 2008)
TCP OUT (client): 577 MBits/sec TCP IN (server): 733 MBits/sec
UDP¶
UDP OUT (client): 697 MBits/sec UDP IN (server): 618 MBits/sec
Measured "100Mbit" performance using MitySOM 5CSX-H6-42A-RC module on 5CSx Development Kit Board with 100Mbit hub¶
stmmaceth ff702000.ethernet eth0: Link is Up - 100Mbps/Half - flow control off
iperf version 3
TCP OUT (client): 88 MBits/sec TCP IN (server): 79 MBits/sec
Measured "10Mbit" performance using MitySOM 5CSX-H6-42A-RC module on 5CSx Development Kit Board with 10Mbit hub¶
stmmaceth ff702000.ethernet eth0: Link is Up - 10Mbps/Half - flow control off
iperf version 3
TCP OUT (client): 5.4 MBits/sec TCP IN (server): 7.8 MBits/sec
