Building the FPGA project and Bootloader with Quartus Pro 26.1¶
Introduction¶
The reference project for the MitySBC-Agilex5 requires the Quartus Pro 26.1 tools installed and in your path.
Please review the Prerequisites for software tool dependencies before attempting to build the projects.
| Quartus Example Projects | git://support.criticallink.com/home/git/mitysbc-a5-ref.git | pro_26.1_stable |
Quick steps to build¶
Clone the repository¶
git clone -b pro_26.1_stable git://support.criticallink.com/home/git/mitysbc-a5-ref.git
Navigate into the folder for the reference Quartus project desired to build (E.g. MODEL_NUMBER/mitysbc-a5e-ref-base)¶
cd mitysbc-a5-ref/A5ED-B96-C7F-RC-SBC-X/mitysbc-a5e-ref-base
make jic
Program the QSPI NOR with the preloader¶
Bootloader¶
Bootloader Environment¶
The bootloader environment script can be found in scripts/boot.cmd. This is bootloader script that is ran as part of the boot process. The script can be compiled by running the following:
make uboot_script
The compiled output script will be in scripts/boot.scr, this belongs in the FAT partition
