Building the Filesystem¶
Introduction¶
The filesystem is built through Yocto. The Yocto version is scarthgap and should be compiled using Ubuntu 22.04.
The meta-layers for the Yocto build are as follows.| Repository | URL | Branch |
| poky | https://git.yoctoproject.org/poky | scarthgap |
| meta-openembedded | https://github.com/openembedded/meta-openembedded | scarthgap |
| meta-mitysom | https://support.criticallink.com/git/meta-mitysom.git | scarthgap |
It is recommended to use Docker for the Yocto build. Instructions for installing Docker can be found here: Docker Installation Guide
The recommended Docker container can be fetched using the command below.
Setting up Yocto¶
Clone the Yocto layers¶
git clone -b scarthgap https://git.yoctoproject.org/poky cd poky git clone -b scarthgap https://github.com/openembedded/meta-openembedded git clone -b scarthgap https://support.criticallink.com/git/meta-mitysom.git
Launch the Docker container¶
Source the Yocto environment¶
. ./oe-init-build-env
Copy the example configuration files¶
cp ../meta-mitysom/conf/bblayers.conf.sample conf/bblayers.conf cp ../meta-mitysom/conf/local.conf.sample conf/local.conf
Performing the Yocto build¶
Build the filesystem¶
MACHINE=mitysbc-agilex5 bitbake mitysom-image-base
Outputs¶
| Description | Location |
| Filesystem Tarball | <Yocto Directory>/build/tmp/deploy/images/mitysbc-agilex5/mitysom-image-base-mitysbc-agilex5.tar.gz |
Build the SDK¶
Build the SDK¶
MACHINE=mitysbc-agilex5 bitbake mitysom-image-base -c populate_sdk
Outputs¶
| SDK Script | <Yocto Directory>/build/tmp/deploy/sdk/mitysom-*mitysom-image-base-*.sh |
