A5E 10 Gigabit Ethernet SFP+ Example¶
Overview¶
This example demonstrates 10 Gigabit Ethernet operation over the SFP+ port on the MitySOM-A5E Mini
development kit using Intel's GTS (General Transceiver Subsystem) Ethernet IP. The design includes
Intel's reference packet_client and loopback_client modules, along with Signal Tap instances for
monitoring transmit and receive traffic at the IP boundary.
The packet client generates raw Ethernet frames and reports transmit/receive statistics through a
memory-mapped register interface accessible from the HPS via the lightweight HPS-to-FPGA bus.
Supported Hardware¶
- MitySOM-A5E Mini baseboard (all module variants)
- A5ED-B14-1X8-MRC-B0 (default)
- A5ED-B14-1X4-MRC-B0
- A5ED-B06-1X2-MRI-CS
- A5ED-B9-XXF-RC-X
This example was tested using two MitySOM-A5E Mini development kits connected back-to-back with
SFP-10G-SR transceivers and a crossover fiber cable.
Known Issues and Limitations¶
- This example uses the raw packet generation logic from Intel's reference design. It does not include
formal Linux Ethernet drivers for standard network stack operation. - Only one transceiver interface (SFP or USB3) may be active at a time. Enabling
SFP_EXAMPLEwill
automatically disable USB3 during project generation. - The client loopback mode has not been fully validated.
Requirements¶
- Quartus Prime Pro Edition 25.3.1
- AArch64 cross-compiler toolchain (e.g.,
aarch64-none-linux-gnu-gccoraarch64-linux-gnu-gcc) - Reference SD card with a compatible Linux filesystem
- This project is configured for HPS-first boot
Building the FPGA Design¶
Step 1 — Check your configuration (optional but recommended)¶
Before generating the project, verify that the settings look correct for your target hardware. ReplaceAGILEX5_MODEL with the model number printed on your module label.
make AGILEX5_MODEL=A5ED-B14-1X8-MRC-B0 SFP_EXAMPLE=1 preview_config
SFP_EXAMPLE=1 is the default for all MitySOM-A5E Mini model strings, so it may be omitted for
convenience. Review the printed configuration. If everything looks correct, proceed to the next step.
Step 2 — Generate the project from TCL¶
make AGILEX5_MODEL=A5ED-B14-1X8-MRC-B0 generate_from_tclThis command:
- Cleans any previously generated files
- Generates the Quartus project files (
.qpf,.qsf), top-level HDL, and SDC from the TCL scripts - Generates the Platform Designer (
.qsys) system
Step 3 — Build the JIC¶
make jicThis will:
- Run the full Quartus compile flow (synthesis, place, route, timing analysis)
- Clone and build ARM Trusted Firmware (branch
QPDS25.3_REL_GSRD_PR) if not already present - Clone and build U-Boot SPL (branch
socfpga_v2025.07) if not already present - Package the resulting SOF with the U-Boot SPL into
output_files/a5e.jic
Programming the Board¶
Flash the JIC into the on-board QSPI NOR flash via JTAG using the Quartus programmer. If multiple
boards are connected, jtagconfig can be used to identify cable indices.
jtagconfig --setparam 1 JtagClock 16M quartus_pgm -c 1 -m jtag -o "ip;output_files/a5e.jic@2"
After flashing, power-cycle the board.
Also copy the updated boot.scr to the SD card boot partition:
cp scripts/boot.scr /path/to/sdcard/boot/
Running the Test¶
Non-loopback bidirectional flow (two boards)¶
Connect two MitySOM-A5E Mini boards back-to-back via SFP+ and boot both boards into Linux.
HPS GPIO quick reference (SFP mapping)¶
The SFP control/status signals are connected to the HPS general-purpose interface bits as follows:
| HPS GP bit | Direction | SFP/GTS signal | Notes |
s_hps_gp_out[7] |
HPS -> FPGA | SFP_TX_DIS |
Transmit disable control |
s_hps_gp_out[8] |
HPS -> FPGA | SFP_RS0 |
SFP rate-select control |
s_hps_gp_in[4] |
FPGA -> HPS | o_tx_pll_locked |
GTS TX PLL lock status |
s_hps_gp_in[6] |
FPGA -> HPS | o_rx_pcs_ready |
GTS RX PCS ready status |
s_hps_gp_in[13] |
FPGA -> HPS | SFP_TX_FLT_N |
Module TX fault (active low) |
s_hps_gp_in[14] |
FPGA -> HPS | SFP_MOD_PRSNT_N |
Module present (active low) |
s_hps_gp_in[15] |
FPGA -> HPS | SFP_LOS |
Loss-of-signal indicator |
s_hps_gp_in[16] |
FPGA -> HPS | s_sys_pll_locked |
System PLL locked status |
For the examples below, memtool 0xF8D08200 1 reads the HPS GP input register.
1. Verify the link is up
Check GTS status via the HPS general-purpose input register. Bit 6 (o_rx_pcs_ready) and bit 4
(o_tx_pll_locked) should read 1 when the link is established:
2. Start transmitting packets (run on both boards)
memtool 0x22000000=5
3. Stop transmitting
memtool 0x22000000=1 memtool 0x22000000=0
4. Read packet statistics
memtool 0x22000000 32
The 32-bit registers at the following offsets report packet counts:
| Address | Description |
0x22000010 |
Transmitted packets |
0x22000014 |
Received packets |
0x22000018 |
Received packets with errors |
5. Read GTS Ethernet statistics registers
Dump the 10 GbE RX statistics counters:
memtool 0x20150000 64
Dump the 10 GbE TX statistics counters:
memtool 0x20160000 64
Register definitions are documented in the Intel 10/25 GbE GTS Statistics Counters reference.
Loopback flow (single board)¶
1. Configure the loopback board
memtool 0x20024040=0xF
2. Configure the transmit board and start sending
memtool 0x20024040=5
memtool 0x20024040=7
memtool 0x20024000 32
0x20024010 |
0x20024014 |
Received packets |
0x20024018 |
Accessing Signal Tap¶
Signal Tap instances are included for monitoring transmit and receive data at the packet client
interface. After a successful compile, open the auto-generated STP file in the Quartus Signal Tap
Logic Analyzer:
./qdb/_compiler/a5e/root_partition/25.3.1/final/1/stp_gen/generated.stp
