A5E-SFP-Fabric-Example
This design enables the Intel Ethernet GTS IP in the sfp_fabric_subsys and brings a single 10G serial lane out to the SFP1 cage. The Intel Ethernet GTS example source files used by this design come from $QUARTUS_ROOTDIR/../ip/altera/ethernet/intel_eth_gts/example_project/common. In the generated system, the GTS IP is instantiated as intel_eth_gts_0 and the example packet source/sink is instantiated as intel_eth_gts_packet_client_0. The serial TX/RX pins from intel_eth_gts_0 connect directly to SFP1_TX_P/N and SFP1_RX_P/N.
This example is provided for the MitySOM and MitySOM-Mini development kits. It is not part of the MitySBC reference designs, which use a QSFP cage instead.
SFP Fabric Subsystem
The data path is intentionally set up for external loopback. Packets return only when the SFP path is looped externally through the module/media. The packet client is the traffic source and sink for this example: it generates packets on the TX side, hands them to the GTS IP, and then counts the packets that return on the RX side after the external loopback path.
| intel_eth_gts_packet_client_0 |
|  packet generator             |
|  packet counters              |
                | Avalon-ST TX/RX
                v
        | intel_eth_gts_0|
                | serial TX/RX
                v
           | SFP1    |
           | cage    |
         external loopback
What This Project Offers
This project provides:
  • A working Intel Ethernet GTS instantiation with a single 10G serial lane routed to the SFP1 cage.
  • A packet generator and packet counters in fabric, so the link can be exercised with no host software beyond memtool.
  • Status PIOs covering clocking, reset acknowledge, link state, system PLL lock and reference-clock buffer protection.
  • SFP module sideband control, through fabric PIOs on the MitySOM-Mini and over I2C on the MitySOM.
  • A starting point for attaching your own Avalon-ST traffic source in place of the packet client.
Building the Example
Refer to Building_fpga_261pro for building the FPGA design. Navigate into the mitysom-a5e[-mini]-ref-sfp-fabric example project before compiling the design.
  • Ensure to flash the resulting a5e.hps.jic onto the hardware
  • Ensure to replace the a5e.core.rbf on the SD card
Using the Example
The packet client control register is accessed over the lightweight bridge at address 0x30000000.
Register Map
The packet counters are 64-bit values split into low/high 32-bit words.
Absolute Address Offset Register Access Description
0x30000000 0x0000 Packet client control RW Bit 0 = start packet generation, bit 2 = continuous mode, bit 4 = select RX loopback path into TX when set, bit 6 = snapshot counters, bit 7 = clear shadow counters, bit 8 = clear TX/RX counters (self-clearing).
0x30000004 0x0004 Test loop count RW Packet-generator loop count.
0x30000008 0x0008 ROM start/end address RW Low field = ROM start address, upper field = ROM end address.
0x3000000C 0x000C Packet client status R Bit 0 = loopback FIFO write-full error, bit 1 = loopback FIFO read-empty error.
0x30000010 0x0010 Latency count RW Read returns the measured latency count in bits [7:0]; bit 31 is used to trigger a latency measurement.
0x30000014 0x0014 Custom destination address low RW Lower 32 bits of the packet-generator destination-address field.
0x30000018 0x0018 Custom destination address high RW Upper destination-address bits in [16:0].
0x3000001C 0x001C Packet gap RW Packet-gap setting for the ROM-based packet generator.
0x30000020 0x0020 TX SOP count low R Low 32 bits of transmitted start-of-packet count.
0x30000024 0x0024 TX SOP count high R High 32 bits of transmitted start-of-packet count.
0x30000028 0x0028 TX EOP count low R Low 32 bits of transmitted end-of-packet count. One EOP corresponds to one transmitted packet.
0x3000002C 0x002C TX EOP count high R High 32 bits of transmitted end-of-packet count.
0x30000030 0x0030 TX error count low R Low 32 bits of transmitted error count.
0x30000034 0x0034 TX error count high R High 32 bits of transmitted error count.
0x30000038 0x0038 RX SOP count low R Low 32 bits of received start-of-packet count.
0x3000003C 0x003C RX SOP count high R High 32 bits of received start-of-packet count.
0x30000040 0x0040 RX EOP count low R Low 32 bits of received end-of-packet count. One EOP corresponds to one received packet.
0x30000044 0x0044 RX EOP count high R High 32 bits of received end-of-packet count.
0x30000048 0x0048 RX error count low R Low 32 bits of received error count.
0x3000004C 0x004C RX error count high R High 32 bits of received error count.
0x30900000 0x00900000 Clock status PIO R See bit definitions below.
0x30900010 0x00900010 Reset status PIO R See bit definitions below.
0x30900020 0x00900020 Link status PIO R/W See bit definitions below.
0x30900030 0x00900030 System PLL lock PIO R See bit definitions below.
0x30900040 0x00900040 SFP input PIO R Only for the MitySOM-Mini. See bit definitions below.
0x30900050 0x00900050 SFP output PIO RW Only for the MitySOM-Mini. See bit definitions below.
0x30800000 0x00800000 Intel Ethernet GTS reconfiguration slave RW IP reconfiguration interface of intel_eth_gts_0.
0x20000500 n/a GTS refclk fail status PIO R On the lightweight bridge outside this subsystem. See bit definitions below.
0x20000520 n/a GTS refclk on PIO W 10-bit register method for re-enabling a refclk buffer. See below.
Status PIO Bit Definitions
Clock status PIO (0x30900000)
Bit Name Description
0 o_cdr_lock RX CDR lock status.
1 o_tx_pll_locked TX PLL lock status.
2 o_tx_lanes_stable TX lane-stability indication.
3 o_rx_pcs_ready RX PCS ready indication.
Reset status PIO (0x30900010)
0 o_rst_ack_n Active-low overall reset acknowledge from the GTS reset logic.
1 o_tx_rst_ack_n Active-low TX reset acknowledge from the GTS reset logic.
2 o_rx_rst_ack_n Active-low RX reset acknowledge from the GTS reset logic.
Link status PIO (0x30900020)
0 o_rx_block_lock RX block lock indication.
1 o_local_fault_status Local fault indication.
2 o_remote_fault_status Remote fault indication.
3 i_stats_snapshot Software-controlled snapshot bit driven from the PIO toward the GTS status interface.
4 o_rx_hi_ber RX high-BER indication.
5 o_rx_pcs_fully_aligned RX PCS fully aligned indication.
System PLL lock PIO (0x30900030)
0 o_sys_pll_locked System PLL lock indication.
GTS refclk fail status PIO (0x20000500)
This PIO exposes gts_rst_seq_left.o_refclk_fail_status[7:0], the status of the GTS input reference clock buffer protection. It sits at 0x20000500, outside the 0x30000000 block used by the rest of this subsystem, because the GTS reset sequencer lives at the top level of the design rather than inside sfp_fabric_subsys. Only the left-hand sequencer is instantiated for this single-lane SFP configuration. The GTS hardware monitors each enabled refclk input buffer and automatically turns a buffer off when it no longer detects a toggling clock at the input (the detector covers 25 MHz to 380 MHz; a clock outside that range is also treated as absent). A bit value of 1 means the corresponding refclk buffer was enabled at configuration but has since been turned off due to the absence of a clock at its input. A bit value of 0 means the buffer has not been turned off.
0 o_refclk_fail_status[0] 1A/4A local refclk buffer status. 0 = buffer on, 1 = buffer turned off (no clock detected at the input).
1 o_refclk_fail_status[1] 1A/4A global refclk buffer status. 0 = buffer on, 1 = buffer turned off (no clock detected at the input).
7:2 o_refclk_fail_status[7:2] Reserved / unused in this single-lane SFP configuration.
NOTE - A refclk buffer that has been turned off by the protection mechanism does not turn back on by itself. On ES silicon, the register method must be used to turn a refclk buffer back on. On production devices, either the register method or the status and control ports method may be used. However, the design is currently only configured to support the register method, which is driven from gts_left_refclk_on_pio, a 10-bit write-only PIO at 0x20000520. See section 3.7.5 of the GTS Transceiver PHY User Guide for more details
SFP input PIO (0x30900040, only for the MitySOM-Mini)
0 SFP1_TX_FLT_N SFP transmitter fault input.
1 SFP1_MOD_PRSNT_N SFP module-present input.
2 SFP1_LOS SFP loss-of-signal input.
For the MitySOM, these values can be read from the PCAL6416A on I2C bus 3 at address 0x20.
SFP output PIO (0x30900050, only for the MitySOM-Mini)
0 SFP1_TX_DIS SFP transmitter-disable output.
1 SFP1_RS0 SFP rate-select output.
Hardware Setup
This example can be run on either the MitySOM Development Kit or the MitySOM-Mini Development Kit.
It can be exercised using either two development kits connected together or a single development kit with the SFP interface looped back.
  • Program a design that includes this SFP fabric example.
  • Install the SFP module(s) on SFP1 and create the external TX-to-RX path. For a two-kit setup, connect the two SFP1 interfaces together. For a single-kit setup, use an external loopback on SFP1.
  • Boot Linux on the HPS so memtool can access the lightweight bridge.
Note: For the MitySOM, the TX Disable line must be configured low for the loopback to work. This can be done by running the following:
i2cset -y 3 0x20 0x06 0xFD
i2cset -y 3 0x20 0x02 0xFD
Note: For the MitySOM, the SFP cage must be installed into J5.
Optional Pre-Check
Before starting traffic, it is useful to confirm the clocks and link-side status bits are alive:
memtool 0x30900000 1
# Expected healthy value: lock/ready bits asserted. Typically 0x0000000F.
memtool 0x30900010 1
# Expected healthy value: active-low reset acknowledge bits deasserted/high. Typically 0x00000007.
memtool 0x30900020 1
# Expected healthy value after link comes up: block lock/alignment asserted and no faults. Typically 0x00000021.
memtool 0x30900030 1
# Expected healthy value: system PLL locked. Typically 0x00000001.
memtool 0x20000500 1
# Expected healthy value: all refclk buffers on. Typically 0x00000000.
The reset-status PIO is mainly a debug aid because its bits are active-low acknowledge signals.
Typical signs of a healthy path are:
  • Clock status shows the lock/ready bits asserted.
  • System PLL lock is asserted.
  • GTS refclk fail status reads as 0x00000000 (no refclk buffer has been turned off).
  • Link status shows RX block lock / alignment once the external loopback path is in place.
Start Packet Generation
Start the packet generator with:
memtool 0x30000000=5
In this example, 5 means:
  • bit 0 = start transmitting packets
  • bit 2 = keep running in continuous mode
Verify TX/RX Packet Activity
Read the TX/RX packet counters and the TX/RX error counters:
memtool 0x30000028 1
memtool 0x30000030 1
memtool 0x30000040 1
memtool 0x30000048 1
For a full 64-bit snapshot, read the 12 words starting at 0x30000020:
memtool 0x30000020 C
To watch the key TX/RX count and error registers in one read, use watch to read the 12 words starting at 0x30000020. The packet counters should keep increasing if the example is working and the SFP path is looped back correctly:
watch memtool 0x30000020 C
Expected behavior:
  • 0x30000028 increments as packets are transmitted by the packet client.
  • 0x30000040 increments as those packets return through the external SFP loopback path.
  • 0x30000030 and 0x30000048 should remain at zero during a clean run.
  • RX should track TX closely in steady state.
If TX counts increase but RX counts stay at zero, the packet generator is running but the serial link is not looping back. In that case, re-check the external loopback path and the status PIO registers at 0x30900000, 0x30900020, 0x30900030 and 0x20000500.
Stop Packet Generation
To stop the example:
memtool 0x30000000=0
