Building the FPGA project and Bootloader with Quartus Pro 26.1¶
1. Prerequisites 2. Building the FPGA and Bootloader 3. Building the Filesystem 4. Deploying the Firmware
Introduction¶
The reference project for the MitySOM-A5E requires the Quartus Pro 26.1 tools installed and in your path.
Please review the Prerequisites for software tool dependencies before attempting to build the projects.
| Platform | Description | Repository | Branch |
| Mity-A5E | Quartus Example Projects | git://support.criticallink.com/home/git/mitysom-a5e-ref.git | pro_26.1_stable |
Quick steps to build¶
Clone the repository¶
git clone -b pro_26.1_stable git://support.criticallink.com/home/git/mitysom-a5e-ref.git
Navigate into the folder for the reference Quartus project desired to build (E.g. MODEL_NUMBER/mitysom-a5e-mini-ref-base)¶
cd mitysom-a5e-ref/A5ED-B14-1X8-MRC-B0/mitysom-a5e-mini-ref-base
make jic
Refer to the 4. Deploying the Firmware section for updating the SD card and flashing the QSPI NOR with the JIC file.
Bootloader¶
Bootloader Environment¶
The bootloader environment script can be found in scripts/boot.cmd. This is bootloader script that is ran as part of the boot process. The script can be compiled by running the following:
make uboot_script
The compiled output script will be in scripts/boot.scr, this belongs in the FAT partition
