MitySOM-A5E FPGA Signal Routing Delays¶
MitySOM-A5E Standard¶
General Notes Regarding FPGA Signal Routing to the SEAM Connectors (J1 and J2) for the MitySOM-A5E Standard module:- All differential pairs target < 5 mil variance between the P and N signal
- FPGA IO pins are length matched among the following groups to a target of < 5 mil
- HSIO Bank 3A Pins
- HSIO Bank 2A Top sub-bank pins
- HSIO Bank 2A Bottom sub-bank pins
- HSIO Bank 2B Top sub-bank pins
- HSIO Bank 2B Bottom sub-bank pins
- HPS GPIO0 pins
- HPS GPIO1 pins
- HVIO Bank 5A pins
- HVIO Bank 5B pins
- HVIO Bank 6A pins
- HVIO Bank 6B pins
- HVIO Bank 6C pins
- HVIO Bank 6D pins
- Transceiver Lanes and reference clock lanes are not group matched, only P/N matched.
The J1_J2_to_FPGA_IO_MitySOM-A5E_Standard_Rev1.xlsx spreadsheet includes detailed routing delay information for all the FPGA IO pins that are directly connected to the SEAM interface connectors for revision -1 of the MitySOM-A5E Standard PCAs.
The J1_J2_to_FPGA_IO_MitySOM-A5E_Standard_Rev2.xlsx spreadsheet includes detailed routing delay information for all the FPGA IO pins that are directly connected to the SEAM interface connectors for revision -2 of the MitySOM-A5E Standard PCAs.
MitySOM-A5E Mini¶
- HSIO Bank 3A Pins
- HPS GPIO0 pins
- HPS GPIO1 pins
Note that due to the size limitations of the MitySOM Mini, the HVIO banks are not tightly length matched. If you are designing a highspeed interface on the MitySOM-A5E Mini HVIO banks, you should review the spreadsheet mentioned below and consider accounting for skew difference on your carrier board design.
The J1_to_FPGA_IO_MitySOM_A5E-Mini_Rev2.xlsx spreadsheet includes detailed routing delay information for all the FPGA IO pins that are directly connected to the SEAM interface connectors for revision -2 of the MitySOM-A5E Mini PCAs.
