DGSATA HDD problem
Added by Dmitry Gorulko over 14 years ago
Hello!
I am trying to connect SATA HDD to Industrial IO devkit, but there is a problem. Boot log:
U-Boot > run flashargs
U-Boot > bootm
## Booting kernel from Legacy Image at c0700000 ...
Image Name: Linux-2.6.34-rc1
Data Size: 2177200 Bytes = 2.1 MB
Load Address: c0008000
Entry Point: c0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.34-rc1 (root@mitydsp) (gcc version 4.3.3 (GCC) ) #1 PREEMPT Thu Mar 31 19:35:51 EDT 2011
Machine: MityDSP-L138
Peripheral Config Block Found
Enet_Config = 2
PHYMask = 0x8
No LCD Configured
UART[0] = 0, 0, 0, 115200
UART[1] = 1, 1, 0, 115200
UART[2] = 0, 0, 0, 115200
SPI[0] = 0, 0, 00, 0, 0
SPI[1] = 1, 1, 01, 0, 30000000
DaVinci da850/omap-l138/am18xx variant 0x1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24384
Kernel command line: mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw,noatime rootfstype=jffs2
PID hash table entries: 512 (order: -1, 2048 bytes)
Memory: 96MB = 96MB total
Memory: 92736k/92736k available, 5568k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff000000 - 0xffe00000 ( 14 MB)
vmalloc : 0xc6800000 - 0xfea00000 ( 898 MB)
lowmem : 0xc0000000 - 0xc6000000 ( 96 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc002b000 ( 140 kB)
.text : 0xc002b000 - 0xc041d000 (4040 kB)
.data : 0xc0438000 - 0xc0468840 ( 195 kB)
Experimental preemptable hierarchical RCU implementation.
NR_IRQS:245
Calibrating delay loop... 149.50 BogoMIPS (lpj=747520)
DaVinci: 144 gpio irqs
regulator: core version 0.5
mityomapl138_init...
mityomapl138_setup_nand: using 16 bit data
EMAC: MII PHY configured, RMII PHY will not be functional
mityomapl138_init: setting phy_mask to 8
mityomapl138_init: no LCD device enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
regulator: VDCDC1: 1150 <--> 1350 mV at 1200 mV
regulator: VDCDC2: 1710 <--> 1910 mV at 3300 mV
regulator: VDCDC3: 1120 <--> 1320 mV at 1800 mV
regulator: LDO1: 1800 mV
regulator: LDO2: 3300 mV
Advanced Linux Sound Architecture Driver Version 1.0.22.1.
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 181
console [ttyS1] enabled
brd: module loaded
at24 1-0050: 256 byte 24c02 EEPROM (read-only)
MityOMAPL138: Found MAC = 00:50:c2:bf:8c:7c
MityOMAPL138: Part Number = L138-FX-225-RC
MityOMAPL138: setting max frequency to 456 MHz
ahci ahci: forcing PORTS_IMPL to 0x1
ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci
ata1: SATA max UDMA/133 irq 67
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bit)
0x000008000000-0x000010000000 : "homefs"
console [netcon0] enabled
ohci ohci.0: DA8xx OHCI
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
cpuidle: using governor menu
usbhid: USB HID core driver
No device for DAI AD73311
Asahi Kasei AK4104 ALSA SoC Codec Driver
No device for DAI AK4535
Cirrus Logic CS4270 ALSA SoC Codec Driver
No device for codec dsd1791
No device for DAI dsd1791
No device for DAI PCM3008 HiFi
No device for DAI SSM2602
No device for DAI tlv320aic23
No device for DAI UDA134X
No device for DAI WM8510 HiFi
No device for DAI WM8728
No device for DAI WM8750
No device for DAI WM8971
No device for DAI WM8990 ADC/DAC Primary
asoc: dsd1791 <-> davinci-i2s mapping ok
soc-audio soc-audio.0: DSD1791 Audio Codec
ALSA device list:
#0: MityDSP-L138 INDIO (dsd1791)
TCP cubic registered
Clocks: disable unused i2c1
Clocks: disable unused emac
Clocks: disable unused lcdc
Clocks: disable unused spi0
Clocks: disable unused mcbsp0
Clocks: disable unused mcbsp1
Clocks: disable unused vpif
regulator_init_complete: incomplete constraints, leaving LDO2 on
regulator_init_complete: incomplete constraints, leaving LDO1 on
regulator_init_complete: incomplete constraints, leaving VDCDC3 on
regulator_init_complete: incomplete constraints, leaving VDCDC2 on
regulator_init_complete: incomplete constraints, leaving VDCDC1 on
emac-mii: probed
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
ata1: SATA link down (SStatus 0 SControl 300)
ata1: exception Emask 0x10 SAct 0x0 SErr 0x4050202 action 0xe frozen t4
ata1: irq_stat 0x00000040, connection status changed
ata1: SError: { RecovComm Persist PHYRdyChg CommWake DevExch }
ata1: hard resetting link
ata1: EH complete
ata1: irq_stat 0x00400040, connection status changed
ata1: limiting SATA link speed to 1.5 Gbps
INFO: task swapper:1 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
swapper D c02f4c54 0 1 0 0x00000000
[<c02f4c54>] (schedule+0x328/0x3c0) from [<c005d134>] (async_synchronize_cookie_domain+0xe0/0x198)
[<c005d134>] (async_synchronize_cookie_domain+0xe0/0x198) from [<c005d210>] (async_synchronize_full+0x18/0x40)
[<c005d210>] (async_synchronize_full+0x18/0x40) from [<c01a0dc0>] (wait_for_device_probe+0x88/0x9c)
[<c01a0dc0>] (wait_for_device_probe+0x88/0x9c) from [<c0009114>] (prepare_namespace+0x38/0x1c8)
[<c0009114>] (prepare_namespace+0x38/0x1c8) from [<c0008484>] (kernel_init+0x118/0x160)
[<c0008484>] (kernel_init+0x118/0x160) from [<c002c938>] (kernel_thread_exit+0x0/0x8)
INFO: task async/0:816 blocked for more than 120 seconds.
async/0 D c02f4c54 0 816 2 0x00000000
[<c02f4c54>] (schedule+0x328/0x3c0) from [<c01cc628>] (ata_port_wait_eh+0x8c/0x114)
[<c01cc628>] (ata_port_wait_eh+0x8c/0x114) from [<c01c3610>] (async_port_probe+0xe4/0x11c)
[<c01c3610>] (async_port_probe+0xe4/0x11c) from [<c005cdd0>] (async_thread+0x124/0x300)
[<c005cdd0>] (async_thread+0x124/0x300) from [<c0056000>] (kthread+0x78/0x80)
[<c0056000>] (kthread+0x78/0x80) from [<c002c938>] (kernel_thread_exit+0x0/0x8)
I am using new SATA HDD (Seagate ST1000DM03) which works fine when connected to PC. I have tried to use a couple of another HDDs (both are WD) and there is no such problem. Any advice?
Thank you!
MW RE: SATA HDD problem - Added by Michael Williamson over 14 years ago
Looks like the drive you are using is a SATA III (Gen3) Drive. There is an errata from TI for the OMAP-L138/AM-1808 that says that SATA III drives will work sync up with the controller on the part. They advise in the errata to use jumper settings to limit the capability/link speed of the drive to SATA II, if they are available.
Sorry.
DG RE: SATA HDD problem - Added by Dmitry Gorulko over 14 years ago
Thanks, Mike. You are right.
