BAopkg update for ALPHA Release 2016.01
Added by Ben Atkinson over 10 years ago
I am using the ALPHA Release 2016.01 with a dbric kernel installed on my target hardware. It seems to be working well, but there is a minor annoyance. I needed rsync on the system, so I performed the following:
$ opkg update
$ opkg install rsync
rsync works fine, but ever since performing the "opkg update" I get the following spam whenever I do "opkg update":
Package libgstapp-0.10-0 version 0.10.36-r9.1 has no valid architecture, ignoring.
Package libgstaudio-0.10-0 version 0.10.36-r9.1 has no valid architecture, ignoring.
Package libgstcdda-0.10-0 version 0.10.36-r9.1 has no valid architecture, ignoring.
Package libgstfft-0.10-0 version 0.10.36-r9.1 has no valid architecture, ignoring.
Package libgstinterfaces-0.10-0 version 0.10.36-r9.1 has no valid architecture, ignoring.
... and on and on for 220 lines.
The contents of /etc/opkg/angstrom-gstreamer.conf is:
src/gz gstreamer http://feeds.angstrom-distribution.org/feeds/v2014.06/ipk/eglibc/armv5te/gstreamer
What should be done to get rid of the gstreamer messages?
Regards,
Ben
Replies (4)
JC RE: opkg update for ALPHA Release 2016.01 - Added by Jonathan Cormier over 10 years ago
This post seems to describe what your reporting. We will need to test the patch. Would you be willing to test if we can send you an updated opkg binary?
https://groups.google.com/forum/#!topic/opkg-devel/hjvqvgTG0gA
BA RE: opkg update for ALPHA Release 2016.01 - Added by Ben Atkinson over 10 years ago
Jonathan,
I saw that post, too. Yes, if you send me the patched binary, I'll try it.
Regards,
Ben
opkg install  libopkg1_0.2.1-r0.100_cortexa8t2hf-vfp-neon.ipk opkg_0.2.1-r0.100_cortexa8t2hf-vfp-neon.ipk
I think this should work. May want to do a m5sum before and after to ensure it did install.
md5sum /usr/bin/opkg
Thanks, Jonathan. That worked!
Regards,
Ben
    (1-4/4)
