How to boot FPGA from U-Boot without having the uboot.env file in my SD card
Added by Shahad Alrawi over 2 years ago
As a follow up from this question:https://support.criticallink.com/redmine/boards/45/topics/6501
Luckily, I was able to compile U-Boot 2019 from your CriticalLink repo and compile the Linux kernal and Yocto Rootfs as specified in: https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Building_Linux_Kernel
Everything worked fine-ish :)
except for FPGA loading from U-Boot. After digging and trying to use the U-Boot environment variables uBootMMCEnv.txt, it seems that I need to know exactly where is everything stored in the SD card partition in order to make it work and therefore I left it and continued without it in the moment. I will just use the default method that uses extlinux.conf in FAT partition as specified in the instruction:
cd $TOP_FOLDER/sd_card
mkdir sdfs && cd sdfs
cp $LINUX_BIN/a9/zImage .
cp $LINUX_BIN/a9/socfpga_cyclone5_socdk.dtb .
mkdir extlinux
echo "LABEL Linux Default" > extlinux/extlinux.conf
echo " KERNEL ../zImage" >> extlinux/extlinux.conf
echo " FDT ../socfpga_cyclone5_socdk.dtb" >> extlinux/extlinux.conf
echo " APPEND root=/dev/mmcblk0p2 rw rootwait earlyprintk console=ttyS0,115200n8" >> extlinux/extlinux.conf
So it booted but stopped here:
What I did afterwards, is I tried manually to load FPGA to see if this is indeed the problem. Therefore I did that by copying the commands from uBootMMCEnv.txt.
Mainly these two commands with all variables as specified.
=> setenv mmcloadfpga "${mmcloadcmd} mmc 0:${mmcloadpart} ${loadfpgaaddr} ${mmcfpgaloc}"
=> setenv fpgaload "bridge disable; fpga load 0 ${loadfpgaaddr} ${loadfpgasize}; bridge enable"
MitySOM-5CSx # printenv mmcloadfpga
mmcloadfpga=ext2load mmc 0:2 0x2000000 /home/root/soc_system.rbf
MitySOM-5CSx # run mmcloadfpga
MitySOM-5CSx # printenv fpgaload
fpgaload=bridge disable; fpga load 0 0x2000000 0x700000; bridge enable
MitySOM-5CSx # run fpgaload
and yoho it booted successfully after a boot command
My question is how can I write these into U-Boot if I don't have uboot.env file written to this SD card?
And I think I'm using some default environment variables with this extlinux.conf for all other booting options that for me it seems hidden.
For reference, I will append the console and the default environment variables of U-Boot of my Linux image (that doesn't boot FPGA automatically) in the attachment.
Thank you.
RE: How to boot FPGA from U-Boot without having the uboot.env file in my SD card - Added by Shahad Alrawi over 2 years ago
I was wondering, I found in u-boot-socfpga/include/configs
#ifndef CONFIG_EXTRA_ENV_SETTINGS
#define CONFIG_EXTRA_ENV_SETTINGS \
"fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
"bootm_size=0xa000000\0" \
"kernel_addr_r="__stringify(CONFIG_SYS_LOAD_ADDR)"\0" \
"fdt_addr_r=0x02000000\0" \
"scriptaddr=0x02100000\0" \
"scriptfile=u-boot.scr\0" \
"fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \
"then source ${scriptaddr}; fi\0" \
"pxefile_addr_r=0x02200000\0" \
"ramdisk_addr_r=0x02300000\0" \
"socfpga_legacy_reset_compat=1\0" \
"prog_core=if load mmc 0:1 ${loadaddr} fit_spl_fpga.itb;" \
"then fpga loadmk 0 ${loadaddr}:fpga-core-1; fi\0" \
SOCFPGA_BOOT_SETTINGS \
BOOTENV
#endif
This prog_core could be responsible about fpga loading?
In other boards I found more clear settings in which the rbf file name is specified. This is taken from u-boot-socfpga/include/configs/u-boot-socfpga/include/configs
"load_fpga=" /* Load FPGA bitstream */ \
"if tftp ${fpga_filename} ; then " \
"fpga load 0 $loadaddr $filesize ; " \
"bridge enable ; " \
"fi\0"
All these source code are from the repo: https://support.criticallink.com/gitweb/?p=u-boot-socfpga.git;a=shortlog;h=refs/heads/socfpga_v2019.10
Hi everyone,
For anyone who is reading, I have figured it out and I hope this will help you.
The U-Boot is running a script, see the bootcmd below
bootcmd= *run fatscrip* ; bridge enable; run distro_bootcmd
fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};then source ${scriptaddr}; fi
Therefore, I just needed to write the commands for loading FPGA into the u-boot.script file and then compile it using mkimage tool in U-Boot.
The u-boot.script file contains
# compile with: mkimage -T script -C none -n "boot" -d u-boot.script u-boot.scr
setenv fpga 0
setenv fpga_data 0x2000000
setenv fpga_size 7007204
setenv fpga_image /home/root/soc_system.rbf
# load FPGA config
bridge disable
ext4load mmc 0:2 ${fpga_data} ${fpga_image}
fpga load 0 ${fpga_data} ${fpga_size}
Note: I deleted the command "bridge enable" at the end since it is already done in bootcmd.
Then compile it using the command:
u-boot-socfpga/tools/mkimage -T script -C none -n "boot" -d u-boot.script u-boot.scr
Note: mkimage tool will only be shown after you compile your U-Boot.
Then write the u-boot.scr file into the FAT partition with the other files such as the zImage and .dtb file.
This workaround solution is based on this thread: https://forum.rocketboards.org/t/cyclone-v-uboot-socfpga-with-spl-fpga-load/2309/4
