We have lost our frame buffer on AM62x
Added by Nathan Wright 5 months ago
Hi guys,
We've been focusing a lot on our legacy am57x board in our layer.
So it is highly likely that I somehow broke this in the am62x portion.
I guess I am looking for help on where to start.
Basically, I've got no /dev/fb0 device anymore. So psplash doesn't launch...
root@mitysom-am62x-ep00119:~# psplash
Error opening /dev/fb0
I do see this in dmesg on start up and whenever I plug in the usb/hdmi display.
[ 9024.250083] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[ 9024.258547] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
Checking the config for frame buffer related thingies...
root@mitysom-am62x-ep00119:~# cat /proc/config.gz | gunzip | grep CONFIG_FB | grep -v ^#
CONFIG_FB=y
CONFIG_FB_SIMPLE=y
CONFIG_FB_CORE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB_DEVICE=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_DMAMEM_HELPERS=y
CONFIG_FB_IOMEM_FOPS=y
CONFIG_FB_IOMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS_DEFERRED=y
CONFIG_FB_MODE_HELPERS=y
Our image is basically... (broken up over a couple of different includes, I've merged them here)
require recipes-core/images/arago-image.inc
ARAGO_BASE_IMAGE_EXTRA_INSTALL ?= "\
psplash \
audit \
git-revisions \
swupdate \
swupdate-www \
swupdate-cert \
u-boot-fw-utils \
pru-icss \
packagegroup-arago-tisdk-crypto \
gdbserver \
ptpd \
IMAGE_INSTALL += "\
packagegroup-arago-base \
packagegroup-arago-console \
${ARAGO_BASE_IMAGE_EXTRA_INSTALL} \
None of this stuff messes with graphics or frame buffers. I'm stumped.
Any help would be appreciated!
Nathan
Replies (6)
RE: We have lost our frame buffer on AM62x - Added by Jonathan Cormier 5 months ago
Can you check to see if the GPU driver is loaded? If you've been building custom kernels outside of yocto, its pretty easy to lose the gpu driver and that can break the /dev/fb0
root@mitysom-am62x:~# find /lib/modules/ -name pvr* /lib/modules/6.6.58-g-gd584bc2c0050/updates/pvrsrvkm.ko root@mitysom-am62x:~# lsmod | grep pvr pvrsrvkm ...
https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Linux_Kernel_PVR
RE: We have lost our frame buffer on AM62x - Added by Nathan Wright 5 months ago
Gasp! Eureka, how did I lose those?
root@mitysom-am62x-ep00119:~# find /lib/modules/ -name pvr*
root@mitysom-am62x-ep00119:~# lsmod | grep pvr
Thanks that's probably the nudge I needed.
Hi Jon,
I have restored pvrsrvkm to the target by adding libgles2 recipe to the image.
root@mitysom-am62x-ep00119:~# find /lib/modules -name pvr*
/lib/modules/6.6.58-g-gd584bc2c0050-dirty/updates/pvrsrvkm.ko
pvrsrvkm 1466368 0
drm 667648 7 drm_kms_helper,drm_dma_helper,display_connector,pvrsrvkm,tidss,ti_tfp410
I still have no frame buffer though.
root@mitysom-am62x-ep00119:~# ls -la /dev/fb*
ls: /dev/fb*: No such file or directory
root@mitysom-am62x-ep00119:~# /usr/bin/fbtest
/usr/src/debug/kms++/2.1/utils/fbtest.cpp:24: int main(int, char**):
open /dev/fb0 failed
Aborted (core dumped)
Any other hints?
For reference, here is the merged recipe stack of our image with annotations...
psplash \
audit \ <--- a little script that checks the target build
git-revisions \ <--- creates /etc/git-revisions with layer stack revisions
swupdate \ <--- next 4 are all about os management
swupdate-www \
swupdate-cert \
u-boot-fw-utils \
pru-icss \ <--- so we can talk to the co processors
libegl \ <--- next 2 gpu stuff
libgles2 \
glmark2 \ <--- gpu benchmarker
gdbserver \
ptpd \
IMAGE_INSTALL += "\
Nathan
Thanks Nathan, thats progress. Can you send me your dts/dtb and defconfig?
In attempting to gather that info, I saw that there were some upstream changes to the devkit dts file that our copy did not have.
After syncing our dts with the devkit dts, the frame buffer is back!
Thanks for your help.
Great, good to hear
