Converting FPGA Design from MityDSP to MityDSP-XM¶
This page describes the process of converting the VHDL for an FPGA design from targeting the MityDSP platform to compile the design for the MityDSP-XM.
Step 1 - Change Top level Entity Port Declarations¶
The MityDSP-XM uses a shift register to drive the LED and additional bank select bits on the larger flash. The shift register data/LED and clk signals use the pins that were previously direct connects. Comment out the o_fl_bank_sel_n and o_user_led_n ports and uncomment the o_sba_led and o_sba_clk ports.
MityDSP Ports:
o_fl_bank_sel_n : out std_logic; o_user_led_n : out std_logic; -- o_sba_led : out std_logic; -- o_sba_clk : out std_logic;
MityDSP-XM Ports:
-- o_fl_bank_sel_n : out std_logic; -- o_user_led_n : out std_logic; o_sba_led :out std_logic; -- serial-bank-address data / user LED (FPGA_INIT_B/LED/SBA) o_sba_clk :out std_logic; -- serial-bank-address clock
Step 2 - Add sba_ Signals¶
Place the following signal declarations with the other signals (before the "_begin_" keyword).
-- Bank select signals signal t_sba_clk, sba_led : std_logic := '1';
Step 3 - Add sba_ Logic¶
Place the following logic near the end of the VHDL file replacing the old o_fl_bank_sel_n and o_user_led_n logic (old logic is commented out below).
------------------------------------------------------------------------------------ -- Top Level I/O Assignments ------------------------------------------------------------------------------------ --o_fl_bank_sel_n <= '0' when t_fl_bank_sel_n='1' else 'Z'; --o_user_led_n <= not led_enable; o_sba_led <= sba_led; o_sba_clk <= 'Z' when t_sba_clk = '1' else '0';
Step 4 - Update the base_module Instantiation¶
Use the "MityDSP-XM" config; update the bank select ports.
------------------------------------------------------------------------------ -- Base Module ------------------------------------------------------------------------------ inst_base_module: base_module generic map( CONFIG => "MityDSP-XM" -- "MityDSP" | "MityDSP-XM" | "MityDSP-Pro" ) port map( emif_clk => emif_clk, . . . -- i_bank_zero_clr => '0', -- t_bank_sel_n => t_fl_bank_sel_n, -- o_led_enable => led_enable o_sba_led => sba_led, t_sba_clk => t_sba_clk );
Step 5 - Update the Pin Assignments in the UCF Constraints File¶
Comment out the two MityDSP signals and uncomment the MityDSP-XM sba signals.
# MityDSP(Std) Flash Bank Select Connections #NET "o_fl_bank_sel_n" LOC = "G2" | IOSTANDARD = LVCMOS33 ; #NET "o_user_led_n" LOC = "N9" | IOSTANDARD = LVCMOS33 ; # MityDSP-XM Flash Bank Select Connections NET "o_sba_clk" LOC = "G2" | IOSTANDARD = LVCMOS33 ; NET "o_sba_led" LOC = "N9" | IOSTANDARD = LVCMOS33 ;
