How To Manually Add Second MAC to Factory Config¶
How to add second MAC address to "factoryconfig" manually:
- Break into UBoot. Ensure you are using the latest UBoot version or your project specific version that supports the second MAC address block.
 - Type "factoryconfig" to record the current settings for backup purposes. i.e.
MitySOM-5CSx # factoryconfig Factory config at 3ffef36c [ 68 bytes] Factory Configuration: Config Version : 1.2 MAC Address : C4:FF:BC:70:42:69 MAC Address2 : 00:00:00:00:00:00 Serial Number : 19032198 Model Number : 5CSX-H6-42A-RC
 - Type "factoryconfig set" to add the second MAC address. This will allow you to change any of the entries. Press "enter" to leave a field as-is.
 - When you reach the "MAC Address2" field use the "backspace" key to delete the 00:00:00:00:00:00 entry and then enter your new MAC address using the ":" between each byte of the address. i.e.
MitySOM-5CSx # factoryconfig set Factory config at 3ffef36c [ 68 bytes] MAC Address(1): C4:FF:BC:70:42:69 MAC Address(2):
MitySOM-5CSx # factoryconfig set Factory config at 3ffef36c [ 68 bytes] MAC Address(1): C4:FF:BC:70:42:69 MAC Address(2): 11:22:33:44:55:66
 - Press enter to leave the remaining fields as-is.
 - Once you return to the UBoot prompt re-enter the "factoryconfig" command to ensure the fields have been updated properly.
 - The enter the "factoryconfig save" command to write the config back to the EEPROM memory on the module
MitySOM-5CSx # factoryconfig save Factory config at 3ffef36c [ 68 bytes] Factory Configuration Block Saved Configuration Saved
 - Power cycle the board and run the "factoryconfig" command to verify that the config has been updated permanently.
