Can't ping by name
Added by Dmitry Gorulko about 14 years ago
Hello!
Problem is I can't ping any host by name (got "bad address" error), but no problem with ping by IP. I guess it is related to DNS. How can I solve it? (sorry for stupid question, I am nub). Ping to DNS server which I have assigned in /etc/networks/interfaces is fine. Ping to localhost/mityomapl138.local is fine too.
Thank you!
Replies (4)
RE: Can't ping by name - Added by Michael Williamson about 14 years ago
We've noticed that the DNS doesn't get updated automatically as well.
If you know your DNS server, as a workaround, add the following entry to /etc/resolv.conf (you may need to create this file if it's not there).
nameserver your.dns.server.ip
I'll try to circle back about getting it autoconfigured from the udhcp. Probably google will give you an answer quicker.
RE: Can't ping by name - Added by Dmitry Gorulko about 14 years ago
Solved! Thank you!
The only disadvatage is the /etc/resolv.conf file is rewritten (by udhcpc?) on reboot.
I wonder the dns-nameserver parameter in the /etc/network/interfaces has no meaning, even for static ip configuration?
RE: Can't ping by name - Added by Mattias Ekstrom about 14 years ago
I think the dns-* options in /etc/network/interfaces require that you have the resolvconf package installed. Do you have it?
RE: Can't ping by name - Added by Dmitry Gorulko almost 14 years ago
Hello, Mattias!
I have installed resolvconf package after reading your post. Anyway /etc/resolv.conf still beeing empty.
My /etc/network/interfaces:
auto eth0
#iface eth0 inet dhcp
iface eth0 inet static
address 17.6.210.251
netmask 255.255.255.0
gateway 17.6.210.2
dns-nameservers 17.17.17.102
I also changed parameter dns-nameserver to dns-nameservers which was wrong.
