PCNo DVI and serial output from MityDsp-L138 Industrial I/O board
Added by Phil Chen over 13 years ago
We just got the board from Digi-key.
Module Part Number: L138-FX-225-RC S/N: 110174
I/O Board Number: 80-000268RI-2B S/N: 123981
There is no DVI and serial output when power up. Ethernet is up and I can ping the IP but not telnet.
I wonder if it is pre-loaded with correct image. How do I verify it? Thanks.
Phil
BD RE: No DVI and serial output from MityDsp-L138 Industrial I/O board - Added by Bob Duke over 13 years ago
Phil, can you confirm that the serial cable provided with the dev kit has "Null Modem" printed on each connector?
Can you use ssh to connect (not telnet)?
-Bob
PC RE: No DVI and serial output from MityDsp-L138 Industrial I/O board - Added by Phil Chen about 13 years ago
Hi Bob,
There is no "Null Modem" printed on the serial cable provided with the dev kit. It works now after I put a null modem adapter on the cable. Thanks for prompt response.:)
Phil
BD RE: No DVI and serial output from MityDsp-L138 Industrial I/O board - Added by Bob Duke about 13 years ago
I'm glad it's working Phil. I'm locking this thread, but if you have any other questions, please let us know.
-Bob
    (1-3/3)
