Alter Ethernet MAC
Added by Mostafa Afgani almost 11 years ago
Hi, is it possible to alter the 'burned-in' MAC address of an L138F? I know that I can change it using 'ifconfig eth0 hw ether XX:XX:XX:XX:XX:XX' once Linux is up and running but was wondering if it's possible to make this change persistent and active early in the boot process (so hopefully a solution other than a low numberd rc script).
RE: Alter Ethernet MAC - Added by Jonathan Cormier almost 11 years ago
Mostafa,
We store the mac address on a eeprom on the SoM. The settings stored on this can be accessed using the factoryconfig command in U-boot. Beware that you can brick the SOM if you change some of the other fields.
U-Boot > factoryconfig
Factory Configuration:
Config Version : 1.1
MAC Address : 00:50:C2:E6:76:74
Serial Number : 120189
FPGA Type : 4 [XC6SLX45]
Part Number : L138-FI-225-RC
U-Boot > help factoryconfig
factoryconfig - mitydsp-l138 factory config block operations
Usage:
factoryconfig - print current configuration
factoryconfig set
- set new configuration
factoryconfig save
- write new configuration to I2C FLASH
RE: Alter Ethernet MAC - Added by Michael Williamson almost 11 years ago
You might also try this technique, though I am not sure if the current version of the 3.2 kernel has this command line option implemented:
RE: Alter Ethernet MAC - Added by Mostafa Afgani almost 11 years ago
Thanks Jonathan, that's exactly what I was after.
