NSUnable to build root file system
Added by Noman Siddiqui about 15 years ago
Hi Mike,
I was trying to build the root file system using the instructions on the wiki but getting lot of errors. Could you please take a look at the attached file and let me know if i am missing something.
Noman
MW RE: Unable to build root file system - Added by Michael Williamson about 15 years ago
Hi Norman,
A couple of observations:
1) The package name is "build-essential" not "build-essentials", I will try to correct the original wiki page. Sorry about that.
2) When you cloned the openembedded setup, did you check out a specific revision as per the wiki? We don't test against the bleeding edge, but against the commit that is listed in the wiki.
NS RE: Unable to build root file system - Added by Noman Siddiqui about 15 years ago
Hi Mike,
build-essential is now installed. However, i realized that the checkout was not done because it was not in the right directory. I corrected the steps as below:
#bash> export MDK=/home/mitydsp/MDK_2011-03-31
#bash> cd ${MDK}/sw/ARM/linux/oe
#bash> wget http://download.berlios.de/bitbake/bitbake-1.8.18.tar.gz
#bash> tar xzf bitbake-1.8.18.tar.gz
#bash> ln -s bitbake-1.8.18 bitbake
#bash> git clone git://git.openembedded.org/openembedded
#bash> cd openembedded
#bash> git checkout b92a5ec362603f3de9b983128c0a9c464cc4bb65
#bash> export OEDIR=${MDK}/sw/ARM/linux/oe/openembedded
#bash> mkdir build
#bash> . setup-env
My build is still failing i guess because the git.kernel.org is down. Is there anyway to use get the needed repository from somewhere else ?
Noman
In theory, you could point it to support.criticallink.com's tree....
Kind of spooky the amount of time git.kernel.org has been down..... hopefully it will be back shortly....
    (1-3/3)
