FPGA programming
Added by Oleh Mela over 9 years ago
I have board L138-FI-236-RL.
Developed in Xilinx ISE the design fine works on FPGA at use ISE iMPACT.
Please, tell a step-by-step how to create an image for FPGA and how to provide working of the design at power off/power on.
Best regards,
Oleh
RE: FPGA programming - Added by Michael Williamson over 9 years ago
Once you have a bit file that you like you can run the promgen tool to create the binary image to load per this wiki page:
https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/FPGA_Overview
Once you have a binary image, you can choose to program the FPGA from either u-Boot or from the linux command line, the choice depends on your application requirements.
Instructions for flashing the binary image to non-volatile storage and programming the FPGA from u-Boot or linux on boot up can be found here:
https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Programming_the_FPGA
RE: FPGA programming - Added by Oleh Mela over 9 years ago
Thank for your reply Mike.
Is it possible to write an image FPGA through СОМ1 on MityDSP? Whether it is possible to make it under Windows?
Oleh
