ucf file
Added by Scott Whitney over 12 years ago
We have a MityDSP L138 development kit with the Spartan 6 LX16 FPGA. We are in the process of purchasing the MityDSP L138 with the Spartan 6 LX45 PFGAs. Do we use the same ucf file for both fpga's found in the MDK release? That would be fpga/vhdl/MityDSP_L138.ucf. Thanks, Scott
RE: ucf file - Added by Gregory Gluszek over 12 years ago
Hi Scott,
Yes, you should be able to use the same UCF file. The pin mapping between the LX45 and LX16 is the same, the only issue is that there are 7 or 8 pins on the LX16 that are not connected on the LX45. If you try to use these pins you'll get a compilation error. So using the MitDSP_L138.ucf should work for you, but you might need to remove a core if it is using one of those unbonded pins on the LX45.
Let us know if you have any issues.
\Greg
