Spidev issues
Added by Fred Frantz about 8 years ago
The dev kit baseboard file has been modified to include a "spidev" device, and the kernel was compiled to include the SPI device driver for users. However, the expected /dev/spidev0.1 file is not generated. Can a pinmux conflict with other devices cause this problem? A possibly related problem is that ECC errors are preventing the kernel from booting from NAND, but it works from RAM.
Replies (32)
RE: Spidev issues - Added by Fred Frantz about 8 years ago
Correction in above code
fd = open(devname, O_RDWR|O_SYNC);
should be
fd = open(devname, O_RDWR);
RE: Spidev issues - Added by Jonathan Cormier about 8 years ago
I believe you want a single IOCTL. See the attached source code duplex method.
Example usage
tcSPIDevice spi("/dev/spidev1.1"); struct tsSPIConfiguration spi_conf = {}; spi_conf.mnMode = SPI_MODE_3; // SPI transfer mode including polarity and clock phase. spi_conf.mnLsbType = 0; // LSB first/last. spi_conf.mnBits = 8; // The number of bits per word. spi_conf.mnSpeed = 100000; // The speed in Hz. spi.setConfiguration(spi_conf);
spidevice.cpp (3.01 KB) spidevice.cpp | |||
spidevice.h (1.79 KB) spidevice.h |
A single IOCTL call with len=4 returns 4 bytes of 0 value instead of 2 with no difference in the SPI signals.
Fred, I'm not sure what is wrong. Perhaps if you sent us your schematic someone could look it over.
I'm pretty sure the spidev driver works. However you could try implementing a simple kernel driver to access the spi calls directly. Or you can try accessing the spi device from u-boot. Though verify that spi0 is pinmuxed in u-boot first.
U-Boot# help sspi sspi - SPI utility command Usage: sspi [<bus>:]<cs>[.<mode>] <bit_len> <dout> - Send and receive bits <bus> - Identifies the SPI bus <cs> - Identifies the chip select <mode> - Identifies the SPI mode to use <bit_len> - Number of bits to send (base 10) <dout> - Hexadecimal string that gets sent
If you wanted to verify that the spi0 MISO is properly connected to the processors spi0_d1. You could pinmux the pin as a gpio and drive it high/low and check for it on the scope.
static struct pinmux_config __initdata spi0_pin_mux[] = { {"spi0_cs0.spi0_cs0", AM33XX_PIN_OUTPUT_PULLUP}, {"spi0_cs1.spi0_cs1", AM33XX_PIN_OUTPUT_PULLUP}, {"spi0_sclk.spi0_sclk", AM33XX_PIN_OUTPUT_PULLUP}, {"spi0_d0.gpio0_3", AM33XX_PIN_OUTPUT}, {"spi0_d1.gpio0_4", AM33XX_PIN_OUTPUT}, {NULL, 0}, }
RE: Spidev issues - Added by Lukas Aldrich over 5 years ago
I know this is an old thread, but I came across this issue recently. In order to get any MISO data returned, the clock needs to be defined as an input. See AM437x spidev issue - no MISO data where the TI engineer explains this.
RE: Spidev issues - Added by Jonathan Cormier over 5 years ago
Thanks Lukas, we actually found this at the end of May and I made a patch for our 3.2 kernel. But it doesn't look like I pushed it to the support site. Sorry about that. I'll look into getting it released.
https://e2e.ti.com/support/arm/sitara_arm/f/791/p/649334/2395792#2395792
Changes pushed.
https://support.criticallink.com/gitweb/?p=linux-mityarm-335x.git;a=commitdiff;h=193c9d2ab0cdc35ec3a935491d49876374a66639;hp=5686dc6ac6ebf3a5e9cad78e70ab217bc9a0e839
https://support.criticallink.com/gitweb/?p=linux-mityarm-335x.git;a=commitdiff;h=63a39e85f9ec2a2d5fa7bbf1f697db129bca54f8;hp=193c9d2ab0cdc35ec3a935491d49876374a66639
- « Previous
- 1
- 2
- Next »
