MMC/SD card: Bus width is 1 and not 4
Added by V J about 2 years ago
Hi
We have an SD card connected to the MitySOM-5CSX the same way as on the evaluation platform with 4 data lines.
When running SD card read tests we have discovered that the read speed is only 6 MBytes/s, and that is not fast enough in our application:
dd if=/flash/tmp//testfile1.bin of=/dev/null bs=100M count=1 iflag=direct :0+1 records in 0+1 records out 91093652 bytes (91 MB, 87 MiB) copied, 14.8141 s, 6.1 MB/s
cat /sys/kernel/debug/mmc0/ios shows:
clock: 50000000 Hz vdd: 21 (3.3 ~ 3.4 V) bus mode: 2 (push-pull) chip select: 0 (don't care) power mode: 2 (on) bus width: 0 (1 bits) timing spec: 2 (sd high-speed) signal voltage: 0 (3.30 V) driver type: 0 (driver type B)
The clock is as expected (50 MHz), but the bus-width used is 1 and not 4.
I have checked the socfpga_mitysom5csx_devkit.dts file which specifies 4 bits:
&mmc {
    status = "okay";
    num-slots = <1>;
    broken-cd;
    cap-mmc-highspeed;
    cap-sd-highspeed;
    vmmc-supply = <®ulator_3_3v>;
    vwmmc-supply= <®ulator_3_3v>;
    slot@0 {
        reg = <0>;
        bus-width = <4>;
	According to Cyclone V HPS "MMC Support matrix": https://www.intel.com/content/www/us/en/docs/programmable/683126/21-2/mmc-support-matrix.html 4 bit bus and 50MHz clock is supported, i.e. 25Mbytes/s.
Any suggestions on how to reach 25 MBytes/s read speed?
We are using the Rocko branch with kernel 4.9 RT.
BR
VJ
RE: MMC/SD card: Bus width is 1 and not 4 - Added by Daniel Vincelette about 2 years ago
Running in 1 bit mode was a bug in our reference dts, which was fixed in the following patch: https://support.criticallink.com/gitweb/?p=linux-socfpga.git;a=blobdiff;f=arch/arm/boot/dts/socfpga_mitysom5csx_devkit.dts;h=f7ce47549addde30e02090267dfbdd9520a05242;hp=6c5ea6b5a144c92706468f3c321b157635a06521;hb=1ceb949210629d49aad08b75e503e1b7be8e3469;hpb=1692f27e80f89e9bfad9ef4db69dea80daa745d2
bus-width = <4>; needs to be moved out of slot@0 into mmc
Dan
RE: MMC/SD card: Bus width is 1 and not 4 - Added by V J about 2 years ago
Thank you Dan for your fast reply. That did the trick:
dd if=/flash/tmp//testfile1.bin of=/dev/null bs=100M count=1 iflag=direct 0+1 records in 0+1 records out 91093652 bytes (91 MB, 87 MiB) copied, 3.88195 s, 23.5 MB/s
BR
VJ
