BKHow to access gpio using c code in yocto linux, which is created using PIO IP with HPS
Added by Bhardwaj Kotha over 2 years ago
I have added pio ip (output only) to the HPS block design in platform designer, and modified/added gpio block with address specification by converting the dtb file to dts. Again compiled back to new dtb and replaced in pre built os image contained emmc card. After booting I am able to gpio chip in and as /sys/class/gpio/gpiochip1984. I have made pio out signal as external and added to signal tap analyser in top module to view the value. Whaen I try to run echo commands, it is permission denied. How can I access the gpio to send 32 bit data from HPS to FPGA. And my actual requirement is to send 256 bit(32X8) data, is it allowed add any number of pio modules.
Thank you.
GG RE: How to access gpio using c code in yocto linux, which is created using PIO IP with HPS - Added by Gregory Gluszek over 2 years ago
This seems to be a duplicate of https://support.criticallink.com/redmine/boards/45/topics/6705. Please refer to the other linked topic for further details.
Greg
