Building libdaq example applications / libraries¶
The libdaq folder contains a bunch of different libraries for controlling different devices from userspace. Some of these have a "main()" to allow testing the library, and we can build them using the following
source /opt/criticallink/mitysom-335x_2020-08-20/environment-setup-cortexa8t2hf-neon-criticallink-linux-gnueabi git clone https://git.criticallink.com/git/libdaq.git cd libdaq ./autogen.sh ./configure --host=arm-criticallink-linux-gnueabi --enable-factoryconfig=no make -j$(nproc)
The most useful example binaries are likely going to be "gpio", "gpiosingle" and "pwm"
$ ls -l gpio pwm -rwxr-xr-x 1 jcormier engineer 119868 Mar 24 10:28 gpio -rwxr-xr-x 1 jcormier engineer 119868 Mar 24 10:28 gpiosingle -rwxr-xr-x 1 jcormier engineer 51164 Mar 24 10:28 pwm
Building and using gpiosingle with QT and QtCreator¶
- Create a test project for this demo. File -> New File or Project
- Application -> Qt Widgets Application
- Name: TestMe
- Accept defaults. Make sure to pick a valid Kit
- Checkout libdaq inside project folder
Documents/TestMe$ git clone https://git.criticallink.com/git/libdaq.git Cloning into 'libdaq'... remote: Counting objects: 969, done. remote: Compressing objects: 100% (346/346), done. remote: Total 969 (delta 689), reused 872 (delta 616) Receiving objects: 100% (969/969), 549.12 KiB | 8.32 MiB/s, done. Resolving deltas: 100% (689/689), done.
- Open project in QtCreator
- Right-click in the project area and click "Add existing files". Then select "gpiosingle.cpp" and "gpiosingle.h"
- Build the project
Note: If you get various #include file not found warnings, make sure you are compiling for Linux or with the arm cross-compile toolchain. The libdaq libraries are not designed to build for Windows. - Open mainwindow.h
- Add @#include "libdaq/gpiosingle.h"
- Under private and the mainwindow ui, add
Ui::MainWindow *ui; MityDSP::tcGpioSingle redLed;
- Open mainwindow.cpp
- Above the class, add:
#define GPIO_TO_PIN(bank, gpio) ((bank)*32 + (gpio))
Note: This changes depending on the processor, the above is correct for the AM335x. The L138 however would be 16 instead of 32...- In the constructor, initialize the gpio to the correct gpio number, and ensure the direction is set
Note: gpio1_12 was picked at random, the devkit doesn't have any gpios attached to LEDs. This is just an exampleMainWindow::MainWindow(QWidget *parent) : QMainWindow(parent) , ui(new Ui::MainWindow) , gpioRedLed(GPIO_TO_NUM(1,12)) // gpio1_12 { ui->setupUi(this); gpioRedLed.setDirection(1, 0); // Set gpio as output low }
- Add a ToggleLED button to the mainwindow form and create a clicked handler
- Setup click handler to get current gpio value and flip it so we toggle the LED on then off each time the button is pushed
void MainWindow::on_pbToggleLed_clicked() { int ret; unsigned int value; ret = gpioRedLed.GetValue(value); if (ret < 0) { qDebug() << "Error: Failed to get gpio value"; return; } ret = gpioRedLed.SetValue(!value); if (ret < 0) { qDebug() << "Error: Failed to set gpio value"; return; } }
Attached modified mainwindow files: mainwindow.h mainwindow.ui mainwindow.cpp
