Change List (2018 April MDK Release)¶
Root File System Changes¶
- Removed ltp (Linux Test Project) packages.
- Added PVR kernel module
Kernel Changes¶
- Add FIT source.
- Unified SOM variant device trees. There's now one device tree for all SOM variants.
Note: This new device tree only works with the 2018 April MDK U-Boot. Older MDK U-Boot releases will not work.
U-Boot Changes¶
- Added FDT system configuration. U-Boot will now fix-up the device tree on boot.
These fix-ups are applied based on the SOM's NAND and NOR configuration. The fix-ups are located in the device tree. See the device tree includes,am335x-mitysom-<NAND size>.dtsi
andam335x-mitysom-NOR.dtsi
, in the kernel source.
