mitydsp L138 starter file
Added by Krishna Vallabhaneni over 13 years ago
Downloaded http://support.criticallink.com/redmine/attachments/1659/CL_MityDSPL138_StarterWare_06_20_12.zip
unable to unzip the file. Winzip complains that it is not a valid archive file.
I am looking for a valid gel or ccxml file fot CCS V5.
Where can I get it
RE: mitydsp L138 starter file - Added by Dominic Giambo over 13 years ago
Sorry you seem to be having issues downloading the file. I tried here and was able to download the file and extract it successfully - probably an error occurred during your download. The copy you attached to your post was only 235.1 KB, the real download should be over 97 MB.
In any case, I attached just the gel files you were looking for, hopefully that is more convenient for you if it is all you require.
- Dominic
| L138_gel.zip (68.4 KB) L138_gel.zip |
RE: mitydsp L138 starter file - Added by Krishna Vallabhaneni over 13 years ago
Dominic,
Download of the starter file is succussful.Unzip is failing. attached is the screenshot of the message. Winzip works withw the gel file you sent me.
RE: mitydsp L138 starter file - Added by Conor O about 13 years ago
IE9 has a download manager which might be better than previous attempts (which are terrible 1995-2011). In previous versions of Internet Explorer, a failed download will yield no warnings or errors whatsoever. Which is why I personally use curl (http://curl.haxx.se/). Or wget under Linux (use the VM to try!). Both tools will tell you if something went wrong. IE will not.
Note also that a further attempt to download the file may (not always) see the file in IE's cache. So IE will use that instead of downloading anything at all, and give you the exact same failed result. To try properly, you have to clear the cache (Tools/Delete browsing history) and retry. It's rather irritating.
Conor.
