MMC mount in Nand Boot
Added by Manjunath K S over 6 years ago
we have flashed u-boot and kernel to Nand and trying Nand boot of the kernel, after kernel boots up,
When we insert SD card(MMC) , it is not mounting. What could be the problem in rootfs or kernel.
Hardware+
We are using the “MitySOM-335x Processor Card” in our target board. On the processor card with we have AM3359 mounted. We have Micrel KSZ9021 Phy connected to external interface as per “MitySOM_Ethernet_Interface.xlsx”
Development environment:+
We are using TI SDK 05.03.00 for building u-boot and Kernel.
Please help us.
Regards,
Manjunath
Replies (4)
RE: MMC mount in Nand Boot - Added by Jonathan Cormier over 6 years ago
Does the same u-boot and kernel behave the same using our devkit? Can you attach a full boot log showing the problem?
RE: MMC mount in Nand Boot - Added by Manjunath K S over 6 years ago
Hi ,
We don't have your devkit to test on.
I cant explain in log as there is no log telling mounted or unmounted.
Regards,
Manjunath
Is your hardware using the same mmc port as the devkit? If so then no changes to the software should be needed unless your using a microsd without card detect. If there is no card detect pin, you need to disable the pin in u-boot/kernel.
Hi ,
Yes it is using same mmc port ,Thank you for your suggestions , we were able resolve the issue .
Regards,
Manjunath
