EMC Emissions from MityArm 335X MOdule
Added by Michael Schantzen over 12 years ago
We have done a number of EMC frequency scans on our product using the MityArm 3352-GX-X27-RC module. There are a couple of frequencies that are out of specification to meet the IEC 61000-6-3 Emissions for Residential Environments. I would like to get a list of fundamental frequencies(crystal frequencys, DDR3 bus speed, etc.) used on the 3352-GX-X27-RC module. We are seeing some out of spec quasi-peak readings at frequencies of 192MHz, 210MHz and 292.96Mhz. I have not ruled out that these noise peaks are being generated from our base board but so far I cannot correlate these peaks with any base operating frequencies on our base board. Below is the complete table of frequency scans.
Trace Frequency Level Limit
(MHz) ( dBμV) ( dBμV) (dB)
1 QP 50.0 27.75 40.00 -12.25
1 QP 70.0 36.96 40.00 -3.04
1 QP 100.0 29.17 40.00 -10.83
1 QP 110.0 34.81 40.00 -5.19
1 QP 124.96 24.80 40.00 -15.20
1 QP 130.0 27.92 40.00 -12.08
1 QP 140.0 31.86 40.00 -8.14
1 QP 170.0 25.64 40.00 -14.36
1 QP 180.0 33.11 40.00 -6.89
1 QP 190.0 43.30 * 40.00 3.30
1 QP 200.0 36.23 40.00 -3.77
1 QP 210.0 42.38 * 40.00 2.38
1 QP 224.96 28.31 40.00 -11.69
1 QP 250.0 44.29 47.00 -2.71
1 QP 292.96 51.69 * 47.00 4.69
Mike
Replies (6)
RE: EMC Emissions from MityArm 335X MOdule - Added by Michael Williamson over 12 years ago
Hi Mike,
The module has 2 crystals on it, a 24 MHz (connected to ARM) and a 32 KHz (connected to PMIC).
I don't know off-hand what the switching supply freqencies are on the PMIC, but I would think they aren't above 2 MHz (probably a lot lower).
The arm uses a pretty sophisticated set of PLLs and clock tree to drive the various peripherals, DDR, and core CPU rate. The PLL rates change based on operating point, which by default with the current kernel is a 720 MHZ CPU.
Rather then try to figure out what all the clock outputs are by hand, you should be able to dump out the complete clock tree (all of the frequencies used by the various peripherals) by mounting the debug file system and looking at the clock tree. Check this page out for more information (about half way down), http://processors.wiki.ti.com/index.php/Clock_Framework_User_Guide.
I haven't tried this on the AM335x, but have used it on the DM8148. I am fairly certain the framework is there and enabled, but you may need to rebuild the kernel to enable it.
Something like this might list all the frequencies:
mkdir /mnt/debug mount -t debugfs debugfs /mnt/debug find /mnt/debug -name rate | xargs cat
If you are still having trouble let me know and I can set up a rig here and help walk you through dumping out the data.
RE: EMC Emissions from MityArm 335X MOdule - Added by Michael Schantzen about 12 years ago
Hi Mike,
I had our lead software engineer try to dump the clock tree per the information you provided but he could not access it.
I would appreciate if you could set up a rig and help us through it.
Mike
RE: EMC Emissions from MityArm 335X MOdule - Added by Michael Williamson about 12 years ago
Hi Mike,
We needed to enable a kernel flag here. Here is a dump of the PLL derived clock tree from our dev kit. Most of these frequencies don't leave the CPU. The frequencies should be the same for you with the exception of perhaps a baud rate of a serial port, etc. To enable dumping the clocks, you need to rebuild the kernel with CONFIG_PM_DEBUG and CONFIG_DEBUG_FS enabled.
Hope this helps.
clock-name parent-name rate use-count vtp_clk sys_clkin_ck 12000000 0 timer7_ick l4ls_gclk 100000000 1 timer6_ick l4ls_gclk 100000000 1 timer5_ick l4ls_gclk 100000000 1 timer4_ick l4ls_gclk 100000000 1 timer3_ick l4ls_gclk 100000000 1 timer2_ick l4ls_gclk 100000000 1 timer1_ick l4_wkup_gclk 100000000 1 timer0_ick l4_wkup_gclk 100000000 1 clkout2_ck sysclkout_pre_ck 32768 0 sysclkout_pre_ck clk_32768_ck 32768 0 gfx_ick gfx_l3_gclk 200000000 0 gfx_fclk gfx_fclk_clksel_ck 200000000 0 gfx_fclk_clksel_ck sysclk1_ck 200000000 0 mmc_clk per_192mhz_clk 96000000 0 lcd_gclk disp_pll_clk 300000000 1 gpio3_dbclk clk_32khz_ck 32768 0 gpio2_dbclk clk_32khz_ck 32768 0 gpio1_dbclk clk_32khz_ck 32768 0 gpio0_dbclk gpio0_dbclk_mux_ck 32000 0 gpio0_dbclk_mux_ck clk_rc32k_ck 32000 0 cpsw_cpts_rft_clk dpll_core_m5_ck 250000000 0 cpsw_5mhz_clk cpsw_50mhz_clk 5000000 0 cpsw_50mhz_clk sysclk2_ck 50000000 0 cpsw_125mhz_gclk sysclk2_ck 125000000 1 cpsw_250mhz_clk sysclk2_ck 250000000 0 sysclk_div_ck dpll_core_m4_ck 200000000 0 clk_24mhz per_192mhz_clk 24000000 1 debug_clka_gclk sysclk1_ck 200000000 0 l4ls_gclk core_100mhz_ck 100000000 27 l4fw_gclk core_100mhz_ck 100000000 1 l3s_gclk core_100mhz_ck 100000000 2 l4hs_gclk sysclk1_ck 200000000 1 l4_wkup_gclk sysclk1_ck 100000000 6 gfx_l3_gclk sysclk1_ck 200000000 0 l3_gclk sysclk1_ck 200000000 6 l4_rtc_gclk sysclk1_ck 100000000 0 l4_wkup_aon_gclk sysclk1_ck 200000000 1 l3_aon_gclk sysclk1_ck 200000000 1 wkup_m3_fck l4_wkup_aon_gclk 200000000 0 wdt1_fck clk_rc32k_ck 32000 0 wdt1_ick l4_wkup_gclk 100000000 0 wdt0_fck clk_rc32k_ck 0 0 wdt0_ick l4_wkup_gclk 100000000 0 usbotg_fck usb_pll_clk 960000000 1 usbotg_ick l3s_gclk 100000000 1 uart6_ick l4ls_gclk 100000000 1 uart5_ick l4ls_gclk 100000000 1 uart4_ick l4ls_gclk 100000000 1 uart3_ick l4ls_gclk 100000000 1 uart2_ick l4ls_gclk 100000000 1 uart1_ick l4_wkup_gclk 100000000 1 uart6_fck per_192mhz_clk 48000000 1 uart5_fck per_192mhz_clk 48000000 1 uart4_fck per_192mhz_clk 48000000 1 uart3_fck per_192mhz_clk 48000000 1 uart2_fck per_192mhz_clk 48000000 1 uart1_fck per_192mhz_clk 48000000 1 tptc2_ick l3_gclk 200000000 1 tptc1_ick l3_gclk 200000000 1 tptc0_ick l3_gclk 200000000 1 tpcc_ick l3_gclk 200000000 1 lcdc_ick sysclk1_ck 200000000 0 timer7_fck sys_clkin_ck 24000000 0 timer6_fck sys_clkin_ck 24000000 1 timer5_fck sys_clkin_ck 24000000 1 timer4_fck sys_clkin_ck 24000000 0 timer3_fck sys_clkin_ck 24000000 0 timer2_fck sys_clkin_ck 24000000 1 timer1_fck sys_clkin_ck 24000000 1 timer0_fck clk_rc32k_ck 32000 0 spinlock_fck l4ls_gclk 100000000 0 spi1_ick l4ls_gclk 100000000 1 spi0_ick l4ls_gclk 100000000 1 spi1_fck per_192mhz_clk 48000000 0 spi0_fck per_192mhz_clk 48000000 0 smartreflex1_ick l4_wkup_gclk 100000000 0 smartreflex1_fck sys_clkin_ck 24000000 0 smartreflex0_ick l4_wkup_gclk 100000000 0 smartreflex0_fck sys_clkin_ck 24000000 0 sha0_fck l3_gclk 200000000 0 rtc_ick l4_rtc_gclk 100000000 0 rtc_fck clk_32khz_ck 32768 2 rng_fck l4ls_gclk 100000000 0 pka_fck l4ls_gclk 100000000 0 ocpwp_fck l4ls_gclk 100000000 0 ocmcram_ick l3_gclk 200000000 0 mmu_fck gfx_l3_gclk 200000000 0 mmc2_fck mmc_clk 96000000 0 mmc1_fck mmc_clk 96000000 0 mmc0_fck mmc_clk 96000000 0 mmc2_ick l4ls_gclk 100000000 1 mmc1_ick l4ls_gclk 100000000 1 mmc0_ick l4ls_gclk 100000000 1 mlb_fck sysclk_div_ck 200000000 0 mcasp1_fck sys_clkin_ck 24000000 1 mcasp1_ick l3s_gclk 100000000 0 mcasp0_fck sys_clkin_ck 24000000 0 mcasp0_ick l3s_gclk 100000000 0 mailbox0_fck l4ls_gclk 100000000 0 lcdc_fck lcd_gclk 300000000 4 l4ls_ick l4ls_gclk 100000000 1 l4fw_ick core_100mhz_ck 100000000 1 l4wkup_ick l4_wkup_aon_gclk 200000000 1 l4hs_ick l4hs_gclk 200000000 1 ieee5000_fck l3s_gclk 100000000 0 icss_iep_gclk l3_gclk 200000000 0 icss_uart_gclk per_192mhz_clk 192000000 0 icss_ocp_gclk l3_gclk 200000000 0 i2c3_ick l4ls_gclk 100000000 0 i2c3_fck per_192mhz_clk 48000000 0 i2c2_ick l4ls_gclk 100000000 0 i2c2_fck per_192mhz_clk 48000000 0 i2c1_ick l4_wkup_gclk 100000000 0 i2c1_fck per_192mhz_clk 48000000 0 gpmc_fck l3s_gclk 100000000 1 gpio3_ick l4ls_gclk 100000000 1 gpio2_ick l4ls_gclk 100000000 1 gpio1_ick l4ls_gclk 100000000 1 gpio0_ick l4_wkup_gclk 100000000 1 epwmss2_fck l4ls_gclk 100000000 0 epwmss1_fck l4ls_gclk 100000000 0 epwmss0_fck l4ls_gclk 100000000 0 elm_fck l4ls_gclk 100000000 1 debugss_ick l3_aon_gclk 200000000 1 dcan1_ick l4ls_gclk 100000000 0 dcan0_ick l4ls_gclk 100000000 1 dcan1_fck sys_clkin_ck 24000000 0 dcan0_fck sys_clkin_ck 24000000 1 cpgmac0_ick cpsw_125mhz_gclk 125000000 2 control_fck l4_wkup_gclk 100000000 1 clkdiv32k_ick clk_24mhz 24000000 1 cefuse_iclk l4_cefsue_gclk 100000000 0 cefuse_fck sys_clkin_ck 24000000 0 l4_cefsue_gclk core_100mhz_ck 100000000 0 aes0_fck l3_gclk 200000000 0 adc_tsc_ick l4_wkup_gclk 100000000 1 adc_tsc_fck sys_clkin_ck 24000000 0 l3_instr_ick l3_gclk 200000000 1 l3_ick l3_gclk 200000000 1 core_100mhz_ck sysclk1_ck 100000000 4 usb_pll_clk dpll_per_ck 960000000 1 per_192mhz_clk dpll_per_m2_ck 192000000 7 dpll_per_m2_ck dpll_per_ck 192000000 1 dpll_per_ck sys_clkin_ck 960000000 2 disp_pll_clk dpll_disp_m2_ck 300000000 1 dpll_disp_m2_ck dpll_disp_ck 300000000 1 dpll_disp_ck sys_clkin_ck 300000000 1 emif_fw_fck l4fw_gclk 100000000 1 emif_fck ddr_pll_clk 151500000 1 ddr_pll_clk dpll_ddr_m2_ck 303000000 1 dpll_ddr_m2_ck dpll_ddr_ck 303000000 1 dpll_ddr_ck sys_clkin_ck 303000000 1 mpu_fck dpll_mpu_m2_ck 500000000 2 dpll_mpu_m2_ck dpll_mpu_ck 500000000 1 dpll_mpu_ck sys_clkin_ck 500000000 1 clk_32khz_timer clk_32khz_ck 32768 0 core_clk_out dpll_core_m4_ck 200000000 0 sysclk2_ck dpll_core_m5_ck 250000000 1 sysclk1_ck dpll_core_m4_ck 200000000 6 dpll_core_m6_ck dpll_core_x2_ck 2000000000 0 dpll_core_m5_ck dpll_core_x2_ck 250000000 1 dpll_core_m4_ck dpll_core_x2_ck 200000000 1 dpll_core_x2_ck dpll_core_ck 2000000000 2 dpll_core_ck sys_clkin_ck 1000000000 1 tclkin_ck none 12000000 0 sys_clkin_ck virt_24m_ck 24000000 11 virt_26m_ck none 26000000 0 virt_25m_ck none 25000000 0 virt_24m_ck none 24000000 1 virt_19_2m_ck none 19200000 0 clk_rc32k_ck none 32000 0 clk_32khz_ck none 32768 1 clk_32768_ck none 32768 0
Hi Mike,
Hold on on that last post. We were looking at the numbers and something does not look correct (there should not be a 2 GHz clock or a 1 GHz clock, and the CPU should be running at 700 MHz).
I may have posted this prematurely. Sorry.
Hi Mike,
OK, those numbers were for the CPU running at 500 MHz. The speed of the CPU may change based on what power management scheme (the CPU governor) that is selected in the kernel configuration.
Our default kernel selects "performance", which will ratchet the CPU frequency up and down based on CPU load. If you are using our kernel, the operating frequency may change based on how much load you put on the processor.
So, we will need to know a little more about your operation (or your software guy may need to get more involved) to nail down all of the PLL configuration settings in the CPU.
However, most of the peripheral clocks won't change, just the CPU clocks.
How can we help further, given this information?
Hi Mike,
I am good for now. Thanks for the information.
Regards,
Mike
