NDBreaking changes on early MityARM
Added by Nigel Doe over 12 years ago
I have an early MityARM module and dev kit. On trying to implement the latest software versions I found that the Ethernet interface was not functional. On investigating it appears that there has been a pcb change on the RGMIII_RESETn signal.
Are there any other significant changes such as this that I need to be aware off?
Nigel.
MW RE: Breaking changes on early MityARM - Added by Michael Williamson over 12 years ago
Hello Nigel,
Sorry about that. The description of the hardware changes for the Dev Kit baseboard are here:
https://support.criticallink.com/redmine/projects/5csxbase/wiki/Errata_and_Product_Change_Notifications
The only significant change was the location of the ethernet PHY reset, on this page:
https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/U-Boot_on_the_MitySOM-5CSX
You should see a note about setting the "initphy" u-Boot script to toggle the "old" GPIO position for -1 and -2 boards.
ND RE: Breaking changes on early MityARM - Added by Nigel Doe over 12 years ago
Should have spotted that note but somehow managed to miss it!
Nigel.
    (1-2/2)
