Hob Cannot Build Your Image
Added by Brian Wentworth over 6 years ago
I am using utilizing the "build your own root file system" tutorial, and I am having problems with the yocto GUI Hob. I have added a n image of my problem below.
Thanks for your help
RE: Hob Cannot Build Your Image - Added by Daniel Vincelette over 6 years ago
What OS are you using to try to build yocto? I believe I saw that issue if I tried to use an OS newer than ubuntu 14.04
RE: Hob Cannot Build Your Image - Added by Brian Wentworth over 6 years ago
Yes, I amusing ubuntu 16.04. I read the same thing, so thank you for your help.
    (1-2/2)
