MitySOM-5CSX (5CSX-H6-42A-RI) stops at “Deasserting all peripheral resets” — request for guidance
Added by Anonymous fpga 5 months ago
Hello Critical Link Support,
I’m evaluating a MitySOM-5CSX module (part number 5CSX-H6-42A-RI) and I’m trying to run a test bitstream on the Cyclone V FPGA. I used the SD-card image from your wiki for this module:
Image source: https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki
Flash tool: Win32 Disk Imager
SD card: the card supplied with the dev kit
Setup
Two evaluation kits on hand (same model).
Boot configuration DIP switches set as in the attached photo (SD/MMC boot).
Console via PuTTY at 115200 8N1.
Observed behavior
Board #1 boots and runs normally with its SD card.
Board #2 consistently halts after “Starting kernel … / Deasserting all peripheral resets.”
The same SD card that boots on Board #1 fails on Board #2 with identical symptoms.
Serial log shows I²C/RTC messages (AB1805 write failed), “Factory configuration invalid,” and “FPGA: Could not reset,” before handing off to the kernel. I’ve attached screenshots of the full console output.
What I’ve tried
Reflashed the SD image multiple times (Full format FAT32 when applicable).
Swapped SD cards between the two kits (known-good image).
Verified boot switch positions and power supply.
Same cables/host PC/serial settings for both boards.
Request
Could you help me determine whether this is:
a device-tree / image mismatch I should correct,
a factory configuration that needs to be (re)written,
an FPGA/PMIC/I²C hardware issue on Board #2,
or something else you’ve seen before?
Thank you for your guidance.
Best regards,
Replies (6)
RE: MitySOM-5CSX (5CSX-H6-42A-RI) stops at “Deasserting all peripheral resets” — request for guidance - Added by Mike Fiorenza 5 months ago
Hi Atef,
Thank you for the thorough debug details.
- Have you successfully used this development kit before? Or are these the symptoms you are experiencing after first receiving this development kit?
- Could you provide the serial of both the SOM and development board which are experiencing these issues?
There appears like there are multiple issues going on from your boot log. The I2C bus is unhappy as well as the FPGA is failing to load. My guess is since the FPGA doesn't load it is causing the Kernel to hang on start-up.
I would try the following to further debug:
- I would first try to just re-seat the SOM module. Take the SOM module out of the DIMM connector and put it back in. See if this helps resolve any issues. If it does not, proceed to step 2 below.
- I would try to swap the SOM modules between development kits to see if the issue tracks the SOM.
- Mike
RE: MitySOM-5CSX (5CSX-H6-42A-RI) stops at “Deasserting all peripheral resets” — request for guidance - Added by Anonymous fpga 5 months ago
[https://res.public.onecdn.static.microsoft/assets/mail/file-icon/v2/photo_16x16.png]1000008159.jpg<https://sascailabs-my.sharepoint.com/:i:/g/personal/atef_dorai_cailabs_com/EfLXHLTfMzNHoDiG-PRr9sMBAmPRqgLMED5K8e0Jwf8zUg>
[https://res.public.onecdn.static.microsoft/assets/mail/file-icon/v2/photo_16x16.png]1000008160.jpg<https://sascailabs-my.sharepoint.com/:i:/g/personal/atef_dorai_cailabs_com/ESJeeg5Wq4JFifEO2VQ9xGcB1qkrmHPL_BrOS1egONcK6A>
Hi Mike,
Thnaks for your quick reply.
Here’s what I’ve tried and what I’m seeing:
Reseated the SOM in the DIMM connector → same behavior as before.
Swapped SOMs between kits → when I install the good SOM into the known-problematic carrier, the binary runs and I get the expected results.
For the original kit with issues, this behavior has been present since we received it. I moved on to using the second kit because it works as expected.
I’ve attached the serial numbers for both the SOM and the development kit.
Given the above, could you advise on the next steps to reset/recover the SOM (if there’s a recommended procedure)? If a reset isn’t applicable, can we proceed with an RMA for the affected unit?
Thanks again,
Atef DORAI
[My Logo]
Atef Dorai
FPGA Development Engineer
+33 (0)6 77 14 21 42
1 Rue Nicolas Joseph Cugnot
35000
Rennes
France
Hi Atef,
It sounds like based on your findings the SOM module is the issue. It looks like you may have tried to reply to this post via email, which I do not think works for attachments. Can you either reply again and type the serial numbers as text or attach your files directly to the forum post.
There isn't necessarily a reset procedure for the SOM, as nothing is actually stored on the SOM itself (with the exception of the EEPROM which stores the serial / module number information). But your I2C bus to that EEPROM doesn't appear to be working anyways. I will follow up with you on steps for RMA after I've received the serial number for the module.
- Mike
Hi Mike,
Thanks for your quick reply.
Thanks again,
Atef DORAI
| 1000008159.jpg (2.71 MB) 1000008159.jpg | num serial som | ||
| 1000008160.jpg (3.32 MB) 1000008160.jpg | num serial devkit |
RE: Using the design security for MitySOM-5CSX - Added by Anonymous fpga 4 months ago
I would like to encrypt the FPGA bitstream on the MitySOM-5CSX. I have been referring to Intel’s application note AN557 (Using the Design Security Features in Intel FPGAs) to understand how to enable bitstream (.rbf file) encryption.
I have a few questions regarding your evaluation board:
Have you implemented the necessary circuitry on your eval board to support FPGA bitstream encryption (Design Security)? In particular, I do not see the VCCBAT signal mentioned in the documentation and would like to confirm how this is handled on your hardware.
If bitstream encryption is supported, where and how should the encryption key be stored or programmed on the MitySOM-5CSX?
Is there any recommended way to encrypt the HPS software (preloader, U-Boot, Linux), given that I am currently using an SD card to store and load the binaries?
Thank you in advance for your help.
RE: MitySOM-5CSX (5CSX-H6-42A-RI) stops at “Deasserting all peripheral resets” — request for guidance - Added by Mike Fiorenza 2 months ago
The RMA on this thread has been handled and completed.
For anyone looking for resolution to the question about the encrypted FPGA bitstream, see the following forum post: https://support.criticallink.com/redmine/boards/47/topics/7107
