MitySOM-335x Quick Start Guide
1. Install the latest MDK Release:
The Yocto MDK is released as a self-extracting installer for Linux systems.
  • Download the current release from the Files tab of this support site: https://support.criticallink.com/redmine/projects/armc8-platforms/files
  • Open a shell and run the self-extracting installer. It may be necessary to mark the file as executable.
    chmod +x mitysom-335x-devkit-MDK-20XX-XX-XX.sh
    ./mitysom-335x-devkit-MDK-20XX-XX-XX.sh
  • Select the installation directory and complete the installation. The default location is /opt/criticallink/mitysom-335x_XXXX.
2. Install the git-core and subversion applications:
  • Open a Terminal window on the host machine
  • Run the command, or one appropriate for your machine: sudo apt-get install git-core subversion
  • After the install is finished reboot the machine
3. Building an example application
  • Source the toolchain
    source /opt/criticallink/mitysom-335x_DATE/environment-setup-XXXcriticallink-linux-gnueabi
  • Replace your usual gcc/g++ command with the cross compile equivalent
    arm-criticallink-linux-gnueabi-cpp
    arm-criticallink-linux-gnueabi-g++
    arm-criticallink-linux-gnueabi-gcc
  • All the cross compile tools can be found in: /opt/criticallink/mitysom-335x_DATE/sysroots/i686-clsdk-linux/usr/bin/arm-criticallink-linux-gnueabi/
4. Basic Makefile
Note: Sourcing the toolchain will set the CC environment variable to the correct value
Makefile: The $(CC) line must have one tab for proper Makefile syntax.
HelloWorld: HelloWorld.c
     $(CC) -o HelloWorld HelloWorld.c
5. Next steps:
After booting the SD card included with the MitySOM-335x Development Kit, it is recommended that you try rebuilding U-Boot and the Linux kernel in order to verify that your environment is configured correctly.
You can also update the filesystem on your SD card:
If you are planning to do Qt development, please use this guide to setup your environment:
Useful Links
Critical Link's AM335x Wiki page - This page has an ever expanding base of knowledge that is updated regularly by our engineers
Critical Link Support Site - The main Critical Link Support Website
