Building PCIe Hard IP
This page exists as a starting point for people interested in using the PCIe interface on the Critical Link Development Board. This page contains links to all the necessary portions (FPGA, kernel, dtb, etc.) for getting the system up and running quickly. This page also documents specifics on the PCIe Hard IP and pitfalls that may occur.
Example
Currently we are using a ported version of the RocketBoards.org PCIe Root Port With MSI example. The original unmodified source can be found at http://www.rocketboards.org/foswiki/view/Projects/PCIeRootPortWithMSI.
Fabric Resource Utilization
For the example provided in this Wiki we have recorded the following Cyclone V fabric utilization based upon the 110KLE sized Cyclone V SoC:
Resource Available Used % Used
ALM 41,910 10,230 24%
Total registers N/A 14,246 N/A
Memory (M10K & MLAB) 5.6Mbit 2.7Mbit 48%
DSP Blocks 112 0 0%
Transceivers TX & RX 6 4 67%
PLLs 12 1 8%
DLLS 4 1 25%
Altera PCIe Hard IP Documentation: [[http://www.altera.com/literature/ug/ug_c5_pcie.pdf]]
Output Files
Using a Linux machine (Ubuntu 22.04, is what this was tested on) or WSL2 in Windows (guide for install WSL can be found here: https://learn.microsoft.com/en-us/windows/wsl/install)
  1. Download the pre-built Yocto SDK installer: poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-c5-toolchain-4.0.19.sh
  2. Install the script to /opt/poky/4.0.19/.
    ./Downloads/poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-c5-toolchain-4.0.19.sh
Getting Started
  1. Build the FPGA for the dev_5csx_h6_42a_pcie reference project following the steps in Building the FPGA (Note: the timing may fail when compiling; see Timing with PCIe for information on how to continue the FPGA build).
  2. Build the bootloader following the steps in Building the Bootloader.
  3. Build the filesystem following the steps in Building the Filesystem OR use the provided filesystem mitysom-image-base-mitysom-c5.tar.gz.
  4. Build the sd card following the steps in Building the SD Card Image.
  5. Source the Yocto SDK.
    source /opt/poky/4.0.16/environment-setup-cortexa9hf-neon-poky-linux-gnueabi
  6. Grab the kernel from our Git repo.
    git clone https://support.criticallink.com/git/linux-socfpga.git -b socfpga-6.1.55-lts
  7. Change into that directory.
    cd linux-socfpga
  8. Add the following node within the arch/arm/boot/dts/socfpga_mitysom5csx_devkit.dts file
    soc {
                    pcie_0_msi_to_gic_gen_0: msi@0xff20c000 {
                            compatible = "altr,msi-1.0", "altr,msi-1.0";
                            reg = <0xff20c080 0x00000010>, <0xff20c000 0x00000080>;
                            reg-names = "csr", "vector_slave";
                            interrupt-parent = <&intc>;
                            interrupts = <0 45 4>;
                            msi-controller = <1>;
                            num-vectors = <32>;
                    pcie_0_pcie_hip_avmm: pcie@0xc0000000 {
                            compatible = "altr,pcie-root-port-23.1", "altr,pcie-root-port-1.0";
                            reg = <0xc0000000 0x10000000>, <0xff208000 0x00004000>;
                            reg-names = "Txs", "Cra";
                            interrupts = <0 46 4>;
                            interrupt-controller;
                            #interrupt-cells = <1>;
                            device_type = "pci";
                            bus-range = <0x00000000 0x000000ff>;
                            ranges = <0x82000000 0 0x00400000 0xc0400000 0 0x0fc00000>;
                            msi-parent = <&pcie_0_msi_to_gic_gen_0>;
                            #address-cells = <3>;
                            #size-cells = <2>;
                            interrupt-map-mask = <0 0 0 7>;
                            interrupt-map = <0 0 0 1 &pcie_0_pcie_hip_avmm 1>,
                                    <0 0 0 2 &pcie_0_pcie_hip_avmm 2>,
                                    <0 0 0 3 &pcie_0_pcie_hip_avmm 3>,
                                    <0 0 0 4 &pcie_0_pcie_hip_avmm 4>;
  9. Add the following kernel configs in the arch/arm/configs/mitysom5csx_devkit_defconfig file
    + CONFIG_PCIE_ALTERA=y
    + CONFIG_PCIE_ALTERA_MSI=y
    + CONFIG_PCI_MSI=y
    + CONFIG_BLK_DEV_NVME=y
    + CONFIG_NVME_CORE=y
  10. Set the configuration for the kernel.
    make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 mitysom5csx_devkit_defconfig
  11. Build the kernel. The kernel will be built at arch/arm/boot/zImage.
    make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 zImage
  12. Build the device tree blobs. The device tree blobs will be built in arch/arm/boot/dts.
    make ARCH=arm CROSS_COMPILE=arm-poky-linux-gnueabi- -j8 dtbs
  13. Follow the steps in Building the SD Card Image to replace the kernel and device tree with the new zImage and socfpga_mitysom5csx_devkit.dtb.
Timing with PCIe
When porting the RocketBoards.org project to the Critical Link 5CSX development board there were issues with the system meeting timing. The RocketBoards.org project is targeted at a 5CSXFC6D6, while the Critical Link MitySOM has a 5CSXFC6C6. We were only able to successfully port the example project and not have timing errors if we started with the cv_soc_rp_simple_design.tar.gz.
To continue building the FPGA after the timing failure, run the commands below which will finish the 'make rbf' command.
mkdir -p stamp
touch stamp/quartus.stamp
quartus_cpf -c output_files/dev_5cs.sof output_files/dev_5cs.rbf
