Fail to boot the kernel after running setup.sh in DVSDK 4.03
Added by Derek Tan over 12 years ago
Hi all, I have just running setup.sh in DVSDK_4.03, and MityDSP-L138F could not boot the kernel now.
Serial port outputs:
Configuring 256MB mDDR
Booting TI User Boot Loader
UBL Flashtype: SPI
Starting SPI Memory Copy...
DONE
I2C: ready
DRAM: 128 MB
NAND: 512 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
EMIFA CLock : 100000000 Hz
DSP Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config : 2
MMC 0 Enable : 0
Resetting ethernet phy
Net: Ethernet PHY: GENERIC @ 0x03 [0x8]
BOOTP broadcast 1
DHCP client bound to address 192.168.0.110
Using device
TFTP from server 192.168.0.112; our IP address is 192.168.0.110
Filename 'uImage-da850-omapl138-evm.bin'.
Load address: 0xc0700000
Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ####################################
done
Bytes transferred = 2177264 (2138f0 hex)
  1. Booting kernel from Legacy Image at c0700000 ...
    Image Name: Linux-2.6.34-rc1
    Data Size: 2177200 Bytes = 2.1 MB
    Load Address: c0008000I have
    Entry Point: c0008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
Starting kernel ...
It stops here, no more outputs.
Copy uImage from MDK_2011-03-31 to /tftpboot/uImage-da850-omapl138-evm.bin not works. And uImage in MDK_2013-05-15 not works, either.
Does anybody know what's the matter? Thanks in advance.
Replies (7)
RE: Fail to boot the kernel after running setup.sh in DVSDK 4.03 - Added by Derek Tan over 12 years ago
uboot env:
U-Boot > printenv
flashubl=tftp 0xc0700000 mityomap/UBL_SPI_MEM.ais; sf probe 0; sf erase 0 0x10000; sf write 0xc0700000 0 0x10000
flashrootfs=tftp 0xc2000000 mityomap/mityomap-base-mityomapl138.jffs2; nand erase 0 0x08000000; nand write.jffs2 0xc2000000 0 ${filesize}
mtdids=nand0=nand
bootdelay=4
baudrate=115200
oldbootargs=mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw,noatime rootfstype=jffs2
bootargs=console=ttyS2,115200n8 noinitrd rw mem=32M@0xc0000000 mem=64M@0xc4000000 root=/dev/nfs nfsroot=192.168.0.112:/home/mitydsp/targetfs,nolock ip=dhcp
autoload=no
oldserverip=10.0.0.23
serverip=192.168.0.112
bootfile=uImage-da850-omapl138-evm.bin
oldbootcmd=sf probe 0; sf read 0xc0700000 0x100000 0x280000; bootm 0xc0700000
bootcmd=dhcp;setenv serverip 192.168.0.112;tftpboot;bootm
ipaddr=192.168.0.135
stdin=serial
stdout=serial
stderr=serial
ethaddr=00:50:c2:fc:69:5a
ver=U-Boot 2009.11 (Mar 31 2011 - 19:39:18)
Environment size: 1393/65532 bytes
I have build the kernel with codes in git://support.criticallink.com/home/git/linux-davinci.git
No more output is seen on the console after "booting the kernel"
refer to this article: http://processors.wiki.ti.com/index.php/Kernel_-_Common_Problems_Booting_Linux
re-building the kernel with CONFIG_DEBUG_LL enabled, still no more output.
RE: Fail to boot the kernel after running setup.sh in DVSDK 4.03 - Added by Jonathan Cormier over 12 years ago
Derek,
I'm unclear with what you changed between when it was last working and now.
-Jonathan
Hi Jonathan,
Thank you for your reply:)
I'm using the Industrial IO Development Kit with MityDSP-L138F. No change was made before running setup.sh in DVSDK 4.03.
Is the DVSDK 4.03 suitable to the kit?
RE: Fail to boot the kernel after running setup.sh in DVSDK 4.03 - Added by Michael Williamson over 12 years ago
Hi Derek,
The kernel that comes with the DVSDK (uImage-da850-omapl138-evm.bin) will not work with the MityDSP-L138 and Industrial I/O board, it is setup to work with the OMAP-L138 EVM kit from TI. You should be able to replace that with the uImage provided with the MDK and get past your current boot. You also need to specific the correct console port. The MityDSP-L138 console port must be ttyS1. The EVM uses ttyS2. You need to use the correct console in the bootargs parameter (see the "oldbootargs" you made, the consoles are not the same).
Derek,
Where you aware of this wiki page?
http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Dv_sdk_notes
It may help getting the dv sdk working with our kernel.
-Jonathan
Hi Mike & Jonathan,
Really appreciate your help!
The kit could load the kernel now.
-Derek
    (1-7/7)
