PRU svn authentication failed
Added by Andrew Bean over 8 years ago
When running the following:
svn co https://gforge.ti.com/svn/pru_sw/trunk pru_sw
I get the message
"... Could not authenticate to server: rejected Basic challenge (https://gforge.ti.com)"
Previously, the following worked, but does not work now for some reason (perhaps something changed after doing apt-get update and upgrade?):
svn checkout --username anonymous https://gforge.ti.com/svn/pru_sw/trunk pru_sw
I'm using MityDSP-L138_SDK_2012_06_13.ova. Any help would be greatly appreciated.
Replies (5)
RE: PRU svn authentication failed - Added by Jonathan Cormier over 8 years ago
Found this TI wiki. It appears that you must use the username anonymous with a blank password.
http://processors.wiki.ti.com/index.php/PRU_Linux_Application_Loader#Installing_the_Kernel_Driver
RE: PRU svn authentication failed - Added by Bob Duke over 8 years ago
Andrew, I had no problems with this command:
Can you please try again and if you have problems, please cut and paste your terminal output?
[...]Can you please try again and if you have problems, please cut and paste your terminal output?
I've updated the wiki page Using_PRU, to reflect the need to use the username anonymous.
RE: PRU svn authentication failed - Added by Andrew Bean over 8 years ago
I pinged google just to make sure the internet connection is up. Here's what I get:
mitydsp@mitydsp-dev:~$ cd SVN
mitydsp@mitydsp-dev:~/SVN$ ping www.google.com
PING www.google.com (216.58.192.196) 56(84) bytes of data.
64 bytes from ord30s25-in-f196.1e100.net (216.58.192.196): icmp_seq=1 ttl=50 time=4.63 ms
64 bytes from ord30s25-in-f196.1e100.net (216.58.192.196): icmp_seq=2 ttl=50 time=4.93 ms
64 bytes from ord30s25-in-f196.1e100.net (216.58.192.196): icmp_seq=3 ttl=50 time=4.82 ms
64 bytes from ord30s25-in-f196.1e100.net (216.58.192.196): icmp_seq=4 ttl=50 time=4.71 ms
^C
--- www.google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3007ms
rtt min/avg/max/mdev = 4.639/4.778/4.930/0.120 ms
mitydsp@mitydsp-dev:~/SVN$ svn checkout --username anonymous https://gforge.ti.com/svn/pru_sw
Password for '(null)' GNOME keyring:
svn: OPTIONS of 'https://gforge.ti.com/svn/pru_sw': authorization failed: Could not authenticate to server: rejected Basic challenge (https://gforge.ti.com)
"Password for '(null)' GNOME keyring:" seemed suspect, so i searched on that.
I had to do the following, and then it worked:rm ~/.gnome2/keyrings/*
