Quartus II Subscription Edition Error
Added by Anonymous about 12 years ago
I am using the mityarm_5csx_dev_board project that you guys have. If I use the web edition of quartus to run it, everything is fine, but if I use the subscription edition of quartus ii I get some errors.
First of all, when I open it, it asks me to overwrite the database for revision.
The code will synthesize, but it gives the error at the fitter stage it gives the error:
Error (175020): Illegal constraint of pin to the region (89, 56) to (89, 80): no valid locations in region
Info (175028): The pin name: HPS_DDR_D3
Info (175013): The pin is constrained to the region (89, 56) to (89, 80) due to related logic
Error (175005): Could not find a location with: OCT_CAL_BLOCK_ID of 1 (31 locations affected)
Error (184016): There were not enough single-ended bidirectional pin locations available (26 locations affected)
Error (184016): There were not enough single-ended bidirectional pin locations available (2 locations affected)
Thanks!
Jack
Replies (5)
RE: Quartus II Subscription Edition Error - Added by Gregory Gluszek about 12 years ago
Hi Jack,
What version of the Quartus tools are you using?
That project was built with the 13.0 sp1 tools. If you've updated it to the 13.1 tools you probably need to run the hps_sdram_p0_pin_assignments.tcl. Select Tools -> Tcl Scripts... and then in the tree view you should see Project -> mityarm_5csx_dev_board -> synthesis -> submodules -> hps_sdram_p0_pin_assignments.tcl. If you run that I believe it will take care of the issue.
\Greg
RE: Quartus II Subscription Edition Error - Added by Anonymous about 12 years ago
I tried running the tcl script and it didn't work.
The errors are:
Error: Quartus II 64-Bit TimeQuest Timing Analyzer was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 368 megabytes
Hi Jack,
Are those the same errors you were receiving before? And typically when Quartus reports an error there is a plus symbol next to it that you can use to expand the error message and get more details. Could you provide us with that?
And could you let us know what version of the Quartus tools you are currently using?
\Greg
Hi Greg,
I am using 13.1 Quartus, and I ran the script that you recommended and the error that I sent you was what I got after I ran the script. So it's not from the compiling part, but just the script.
Thanks!
Jack
Hi Jack,
Perhaps the project was corrupted when you upgraded it to the 13.1 tools. I've attached a copy of the project that has been successfully upgraded to build in the 13.1 tools.
Let us know if you have any issues.
\Greg
| mityarm_5csx_dev_board_13_1.zip (108 KB) mityarm_5csx_dev_board_13_1.zip | mityarm_5csx_dev_board project build with 13.1 tools |
