Mitydsp Pro compile and link errors
Added by Krishna Vallabhaneni about 13 years ago
Downloaded MityDSP 2.12 and installed.
Using CCSv5.1.0.09.
Imported C:\MityDSP\2.12\software\demo\CCSV5\UDP_echo project.
Downloaded csl_c6455 library.
Added csl_c6455/inc in the compiler include path.
Added csl_c6455/lib in the linker path, added lib/csl_c6455.lib.
Build complains about undefined error!
What is the fix for this problem?
| ccsconsole.rtf (6.14 MB) ccsconsole.rtf | |||
| builderror.rtf (5.81 MB) builderror.rtf |
Replies (4)
RE: Mitydsp Pro compile and link errors - Added by Michael Williamson about 13 years ago
Hmm.
We'll look some more tomorrow, but the '--define="CHIP_6711"' option to the compiler should not be set for the MityDSP-PRO / MityDSP-6455 platform. You might try removing that from the configuration. (actually, what is the configuration you are trying to build?)
RE: Mitydsp Pro compile and link errors - Added by Krishna Vallabhaneni almost 13 years ago
CHIP_6711 was removed from the compiler predefined variables. The build produces the same errors.
CHIP_6455 was added to predefined variables. The build produced the same errors.
Attempting to build for MityDSP pro - for TI 6455 DSP chip.
Krishna
RE: Mitydsp Pro compile and link errors - Added by Dave Stehlik almost 13 years ago
Hi Krishna,
Assuming you are trying to build for the MityDSP Pro, did you set the active configuration to DebugPro?
That should take care of the defines and I would assume any other problems.
Dave
How do you set the active configuration to DebugPro?
Krishna
