For TI SDK users, skip to A Getting Started Guide for the AM335x Series of System on Modules for TI SDK Release
Getting Started Guide for Yocto MDK September 2015 Release¶
 - Getting Started Guide for Yocto MDK September 2015 Release
 - Getting Started Guide for TI SDK Release
First Steps¶
1. Install the latest MDK Release:
The Yocto MDK is released as a self-extracting installer for Linux systems. It includes a root filesystem, pre-built kernel, u-boot, and MLO images, and a self-contained toolchain for cross compilation. The release is built and tested using Ubuntu Precise 12.04 LTS.
    - Download the current release: https://support.criticallink.com/redmine/attachments/download/9537/mitysom-335x-devkit-MDK-2015-11-18.sh
    - Open a shell and run the self-extracting installer. It may be necessary to mark the file as executable.
chmod +x mitysom-335x-devkit-MDK-2015-11-18.sh ./mitysom-335x-devkit-MDK-2015-11-18.sh
- Select the installation directory and complete the installation. Default is /opt/criticallink/mitysom-335x_DATE
2. Install the git-core and subversion applications:
    - Open a Terminal window on the host machine
    - Run the command, or one appropriate for your machine: sudo apt-get install git-core subversion
    - After the install is finished reboot the machine
To build the kernel, follow Linux Kernel for Kernel Build Instructions
To build U-boot, follow Das U-boot Port for U-boot Build Instructions
Building an example application¶
For making applications we recommend QT. Qt Starter Guide
To build a single c/c++ file¶
- Source the toolchain
source /opt/criticallink/mitysom-335x_DATE/environment-setup-cortexa8t2hf-vfp-neon-criticallink-linux-gnueabi
 - Replace your usual gcc/g++ command with the cross compile equivalent
arm-criticallink-linux-gnueabi-cpp arm-criticallink-linux-gnueabi-g++ arm-criticallink-linux-gnueabi-gcc
 - All the cross compile tools can be found in: /opt/criticallink/mitysom-335x_DATE/sysroots/i686-clsdk-linux/usr/bin/arm-criticallink-linux-gnueabi/
Basic Makefile¶
Note: Sourcing the toolchain will set the CC environment variable to the correct value
Makefile: The $(CC) line must have one tab for proper Makefile syntax.
HelloWorld: HelloWorld.c
     $(CC) -o HelloWorld HelloWorld.c
Useful Links¶
Critical Link's AM335x Wiki page - This page has an ever expanding base of knowledge that is updated regularly by our engineers
Critical Link Support Site - The main Critical Link Support Website
Getting Started Guide for TI SDK Release¶
First Steps¶
1. Download the MitySOM Virtual Machine Image for Virtual Box: https://support.criticallink.com/files/mityarm335x/mityarm-335x_SDK.ova
    - VirtualBox is available here: https://www.virtualbox.org/wiki/Downloads
2. Set up the Virtual Machine (VM) by following this guide: https://support.criticallink.com/files/mityarm335x/readme.pdf
    - The default username and password for this virtual machine is U: mitydsp and P: mitydsp
    - If you are not asked to update the VirtualBox Guest Additions after the VM boots, manually update them by clicking the devices menu in the VirtualBox window, and clicking "Insert Guest Additions CD..." and follow the prompts on screen.
3. Install the git-core and subversion applications:
    - Open a Terminal window on the virtual machine
    - Run the command: sudo apt-get install git-core subversion
    - Enter the password for the current user
Git Basics¶
Critical Link stores all of its up-to-date code on a public Git repository, so understanding basic git commands will be beneficial for keeping your software versions current. If you are familiar with Git already, skip this section.
Useful commands
git status - informs you of the condition of the working directory.
git fetch - updates the local repository with all of the changes since its last update. DOES NOT AFFECT LOCAL FILES
git pull - updates the local repository with all of the changes since its last update PLUS merges the changes from the updates repository into the local files.
git branch - view available local branches. Adding "-a" will show all available branches, including remote ones
git checkout - change to a different local branch.
git checkout -b [name of local branch] [name of remote branch] - change to a remote branch and store a local copy
More git resources
Interactive git cheatsheet
Git from the Bottom Up
Fix toolchain environment-setup script¶
- Open a terminal.
 - Open the /usr/local/ti-sdk-am335x-evm-05.03.02.00/linux-devkit/environment-setup file in the gedit text editor
sudo gedit /usr/local/ti-sdk-am335x-evm-05.03.02.00/linux-devkit/environment-setup
 - Comment out line 10 by placing a hash-tag '#' at the beginning of the line
 - Line 10 should now read: "# export SDK_PATH=/export/space/ti-sdk-am335x-evm-05.03.02.00/linux-devkit"
 - Save file and close gedit
Building the Latest Linux Kernel¶
This guide assumes you have successfully booted the VM and are logged into the desktop
- Open a terminal window (Ubuntu 10.04: There is an icon on the top menu bar. Ubuntu 12.04: Open the Ubuntu menu and search for terminal)
 - In the terminal window, navigate to the projects directory on the VM
cd ~/projects/
 - In the projects directory there are four existing folders. Navigate to the Linux Kernel directory
cd linux-mityarm-335x/
 - Pull the updated repository of the Linux Kernel from Git
git pull
 - Checkout the newest Kernel version and create a local branch.
NOTE: You can view all available branches by running:git branch -agit checkout -b mityarm-linux-v3.2 origin/mityarm-linux-v3.2
 - Verify the correct branch was checked out
git status
A successful checkout will be confirmed by output similar to this:mitydsp@mitydsp-dev:~/projects/linux-mityarm-335x$ git status # On branch mityarm-linux-v3.2 nothing to commit (working directory clean)
 - Download the latest am335x power management binary from Texas Instruments. INCLUDE THE PARENTHESIS
NOTE: This step is only necessary for Kernel version 3.2(cd firmware; rm am335x-pm-firmware.bin; wget --content-disposition "http://arago-project.org/git/projects/?p=am33x-cm3.git;a=blob_plain;f=bin/am335x-pm-firmware.bin;hb=refs/heads/master")
 - Source the cross-compile toolchain from the TI-SDK.
source /usr/local/ti-sdk-am335x-evm-05.03.02.00/linux-devkit/environment-setup
 - Configure the Kernel for the MitySOM Devkit
make ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- mityarm-335x-devkit_defconfig
 - Build the uImage of the Kernel. If your VM has more than one core, adding
-j#, where # is the number of cores, will speed up the build processmake ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- uImage
Once the kernel is done building, you will see output similar to below:Image Name: Linux-3.2.0-00217-g3c4aa5c Created: Mon Feb 3 09:39:45 2014 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3725888 Bytes = 3638.56 kB = 3.55 MB Load Address: 0x80008000 Entry Point: 0x80008000 Image arch/arm/boot/uImage is ready
 - Build and install the Kernel Modules
The variableINSTALL_MOD_PATHMUST BE SET otherwise the files will be installed onto the local machine's filesystem. The path specified by the commands below will install the files in the projects directory under~/projects/rootfs/.Build Modules
make INSTALL_MOD_PATH=../rootfs ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- modules
Install Modulesmake INSTALL_MOD_PATH=../rootfs ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- modules_install
The Kernel and its modules are now built. The uImage file used for boot is located in ~/projects/linux-mityarm-335x/arch/arm/boot/, and the Kernel modules are in ~/projects/rootfs. The Kernel modules will need to be copied on top of the root filesystem that is used with the Kernel.
For more information about the Linux Kernel follow this link: https://support.criticallink.com/redmine/projects/armc8-platforms/wiki/Linux_Kernel
Building the Latest U-Boot¶
cd ~/projects/
 - In the projects directory there are four existing folders. Navigate to the U-Boot directory
cd u-boot-mityarm-335x/
 - Pull the updated repository of U-Boot from Git
git pull
 - Checkout the latest U-Boot and create a local branch
git checkout -b u-boot-2013.10 origin/u-boot-2013.10
git status
A successful checkout will be confirmed by output similar to this:mitydsp@mitydsp-dev:~/projects/u-boot-mityarm-335x$ git status # On branch u-boot-2013.10 nothing to commit (working directory clean)
 - If it hasn't been done already, Source the cross-compile toolchain from the TI-SDK
 - Configure and build U-Boot for the SoM you have
U-Boot must be configured based on your System on a Module's (SoM) NAND size. You can figure out how you need to configure U-Boot with this link, starting on line 19, to find your NAND size based on model number.
For NAND sizes 512MB or larger, use the following command:make ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- mityarm335x_4kpage
For all other modules, use this command:make ARCH=arm CROSS_COMPILE=arm-arago-linux-gnueabi- mityarm335x
U-Boot is now built. The MLO and u-boot.img files needed for boot are located in the U-Boot build directory, ~/projects/u-boot-mityarm-335x/
For more information about u-boot follow this link: https://support.criticallink.com/redmine/projects/armc8-platforms/wiki/Das_U-Boot_Port
Updating your SD Card¶
With your development kit you were provided an SD card. This card comes with a fully operational Linux OS pre-installed. This includes the u-boot.img, uImage, and kernel module files that were just built above.
- Use an SD Card reader to connect the SD card to your computer. If you plug the card reader in and don't see any window pop up, check to see if the device was see by the VM by going to the "Devices" drop down menu in the virtual box window and checking the USB devices. If your card reader doesn't have a check mark next to it, click it and the device will connect to virtual box.
 - Find the mount point of the sd card by running
df
you sould get similar output as seen belowmitydsp@mitydsp-dev:~$ df Filesystem 1K-blocks Used Available Use% Mounted on /dev/sda1 118779164 61357084 51388416 55% / none 1026520 284 1026236 1% /dev none 1030756 252 1030504 1% /dev/shm none 1030756 1836 1028920 1% /var/run none 1030756 0 1030756 0% /var/lock none 1030756 0 1030756 0% /lib/init/rw /dev/sdc3 2822496 69828 2609288 3% /media/START_HERE /dev/sdc1 71133 4139 66995 6% /media/boot /dev/sdc2 909168 658896 204088 77% /media/rootfs
In this case, the SD card'srootfsandbootpartition were mounted in the/mediafolder. - The following commands will copy the Linux Kernel and u-boot images to the
bootpartition of the SD card.
NOTE: It is recommended to back up the stock images that came on the SD card. Do this with the following commands (assuming a mount point in/media/boot)cp /media/boot/u-boot.img /media/boot/u-boot.img.stock cp /media/boot/MLO /media/boot/MLO.stock cp /media/boot/uImage /media/boot/uImage.stock
Copy new images (THESE COMMANDS WILL OVERWRITE THE OLD IMAGES)cp ~/projects/u-boot-mityarm-335x/u-boot.img /media/boot cp ~/projects/u-boot-mityarm-335x/MLO /media/boot cp ~/projects/linux-mityarm-335x/arch/arm/boot/uImage /media/boot
- Copy the kernel modules to the
rootfspartitionsudo cp -r ~/projects/rootfs/* /media/rootfs
The SD card will now have the latest Linux Kernel with modules and u-boot versions recommended by Critical Link.
For more information about the filesystem follow this link: https://support.criticallink.com/redmine/projects/armc8-platforms/wiki/Root_Filesystem
For information on using Code composer to build software, checkout this TI guide. http://processors.wiki.ti.com/index.php/Code_Composer_Studio_v5_Users_Guide
arm-arago-linux-gnueabi-cpp arm-arago-linux-gnueabi-g++ arm-arago-linux-gnueabi-gcc
 - All the cross compile tools can be found in: /usr/local/ti-sdk-am335x-evm-05.03.02.00/linux-devkit/bin
Basic Makefile¶
Useful Links¶
