Mity L138F FPGA -> OMAP interrupt lines
Added by Christopher Brunson over 9 years ago
I was trying to use an FPGA interrrupt which should be serviced by the DSP core in the OMAP.
My FPGA pin map for the interrupt pins is the following:
NET "o_int[1]" LOC = F2;
NET "o_int[0]" LOC = K6;
NET "o_nmi_n"  LOC = N8;
I couldn't find which pins and/or OMAP interrupts these FPGA pins are mapped to on the wiki.
What pins/interrupts do the FPGA pins F2, K6 and N8 map to?
Chris B.
RE: Mity L138F FPGA -> OMAP interrupt lines - Added by Michael Williamson over 9 years ago
Hi Chris,
This post, if for an L138 module, should be in this other forum:
https://support.criticallink.com/redmine/projects/arm9-platforms/boards
This forum / subproject is for the MityDSP-6711 and MityDSP-6455 product lines. The MitySOM-L138 is under the "ARM9" produce base.
But, to answer, I think you can find the information you need in the UCF files in the board support package. Does the FPGA Overview wiki page for the MitySOM-L138 help?
RE: Mity L138F FPGA -> OMAP interrupt lines - Added by Christopher Brunson over 9 years ago
Sorry about that I thought this was the ARM9 forum, I will repost it there.
Chris B.
    (1-2/2)
