XSJTAG_avalon_master access HPS DDR timeout
Added by Xiang Shuai 9 months ago
Using MitySOM_5CSX, I added FPGA to HPS SDRAM interface avalon-mm read-only, and try to using jtag_avalon_master to read out the data from HPS DDR, but always timeout. Need a bridge or something worng?
BR,
Xiang
Replies (14)
DV RE: JTAG_avalon_master access HPS DDR timeout - Added by Daniel Vincelette 9 months ago
Hi Xiang,
When you enabled the FPGA to HPS SDRAM bridge did you also rebuild your preloader and u-boot? This is needed because the HPS is the one that takes these bridges out of reset.
Best regards,
Dan
XS RE: JTAG_avalon_master access HPS DDR timeout - Added by Xiang Shuai 9 months ago
Hi Dan,
Thanks for your information, instead of rebuild preload and u-boot, do you have any command that can do release these bridges out of reset? Now, I can use Putty connect system by SSH.
BR,
Xiang
Hi Xiang,
You would need to update the `fpga2sdram_handoff` variable in u-boot to enable the ports that you would like. Here is the HPS doc on the FPGA port controller register map: https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1411577376106.html
I would still recommend rebuilding the preloader and u-boot because that's normally the foolproof way of enabling the bridge that you want.
Best regards,
Dan
A colleague just informed me that even if you set that variable to enable the bridges, it may still not work because the preloader also enables the bridges as part of configuring the HPS I/Os. Because of this, the correct and supported path is to rebuild and update the preloader and U-Boot with the appropriate bridge settings enabled. This ensures the bridges are released at the correct point in the boot sequence and avoids undefined behavior that can occur if they are manipulated later from user space.
Dan
Thanks Dan, I tried change resigster 0xFFC25080 from 0x00000000 to 0x000003FF, but still timeout. I will update u-boot to try again.
Hi Dan,
I download uboot-socfpga.tar.gz, but I don't know how to update `fpga2sdram_handoff` variable in u-boot. Could you give me a detail instruction ?  Thanks!
BR,
Xiang
Hi Xiang,
The fpga2sdram_handoff vairable will be set from the quartus project so you don't need to manually change it. Here are our build instructions for the preloader and u-boot: https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/Building_uboot_231
Best regards,
Dan
Hi Dan,
I meet an issue at step 4 configure and build U-boot and the SPL.
$ make socfpga_nitysom5cs_defconfig
Makefile:40: *** missing separator. Stop
what can I do?
BR,
Xiang
Hi Xiang,
It looks like you have spelling mistake in your command, it should be the following:
make socfpga_mitysom5cs_defconfig
Best regards,
Dan
Hi Dan,
please see attached picture, that's a typo when I fill this page.
BR,
Xiang
XS RE: JTAG_avalon_master access HPS DDR timeout - Added by Xiang Shuai 8 months ago
Hi Dan,
Do you have any update, what I can do now?
BR,
Xiang
DV RE: JTAG_avalon_master access HPS DDR timeout - Added by Daniel Vincelette 8 months ago
Hi Xiang,
Sorry about the delay. It looks like this is either due to a missing or unexpected character in the U-Boot Makefile (around line 40), or it could be related to your build environment: it looks like you're using our Ubuntu 14.04 VM, which may be too old to build the newer example projects.
Can you please post your Makefile? Also, which branch of our Quartus reference design are you trying to use?
  • 23.1-stable
  • 18.1-stable
From your screenshot it appears you're using the Ubuntu 14.04 VM, which may have issues building these newer projects. We recommend the following Ubuntu versions:
Best regards,
Dan
Hi Dan,
Thanks for your support, I build a envirment with Ubuntu 22.04 and Quartus 23.1; and finish re-build uboot. But when i try to generate SD image file, I got below:
$ make sd_image
scripts/kconfig/conf --syncconfig Kconfig
CFG u-boot.cfg
GEN include/autoconf.mk
GEN incldue/autoconf.mk.dep
CFG spl/u-boot.cfg
GEN spl/include/autoconf.mk
make: *** No rule to make target 'sd_image'. Stop
Looks something has been missed?
BR,
Xiang
Hi Xiang,
Are you using the Makefile at the top of the FPGA project? Or are you using the u-boot Makefile? make sd_image only works for the Makefile at the top of the FPGA project.
Best regards,
Dan
    (1-14/14)
