JBStarter Guide: "Boot the MityDSP-L138 up into linux." - How?
Added by Jeff Benshetler about 14 years ago
Hello. I got the MityDSP hooked up and powered on today. I worked through the Starter Guide, successfully cross-compiling HelloWorld. Then I reached the sentence "Boot the MityDSP-L138 up into linux." How?
I've got the serial connection working and on RESET the output is shown below. What comes next? Sorry, this is a newbie question but 2 hours of searching the site has not resolved my issue. Do I have to load Linux to the board? I don't want to go down that road if it is already loaded.
U-Boot > OMAP-L138/AM-1808/AM-1810 initialization passed!
Configuring 128MB mDDR
Booting TI User Boot Loader
UBL Flashtype: SPI
Starting SPI Memory Copy...
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
EMIFA CLock : 100000000 Hz
DSP Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config : 2
MMC 0 Enable : 0
Resetting ethernet phy
Net: Ethernet PHY: GENERIC @ 0x03 [0x8]
U-Boot >
Replies (11)
TI RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Tim Iskander about 14 years ago
Hmmm
It should autoboot into linux. Can you post the output of the u-boot print command
U-Boot > print
And try just typing boot at the prompt
U-Boot > boot
to see if it boots into linux. The bootcmd environment variable should be set to
"sf probe 0; sf read 0xc0700000 0x100000 0x280000;bootm 0xc0700000"
to boot from SPI NOR flash.
cheers
/Tim
JB RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Jeff Benshetler about 14 years ago
The output of print:
U-Boot > print
bootdelay=3
baudrate=115200
bootfile="uImage"
flashubl=tftp 0xc0700000 mityomap/UBL_SPI_MEM.ais; sf probe 0; sf erase 0 0x10000; sf write 0xc0700000 0 0x10000
flashrootfs=tftp 0xc2000000 mityomap/mityomap-base-mityomapl138.jffs2; nand erase 0 0x08000000; nand write.jffs2 0xc2000000 0 ${filesize}
serverip=10.0.0.23
autoload=no
mtdids=nand0=nand
stdin=serial
stdout=serial
stderr=serial
ethaddr=00:50:c2:bf:8e:12
ver=U-Boot 2009.11 (Mar 31 2011 - 19:39:18)
Environment size: 905/65532 bytes
U-Boot >
The (non)-result of boot:
U-Boot > boot
U-Boot >
I tried setting the bootcmd variable as suggested and the executed boot. This is what I got:
U-Boot > editenv bootcmd
edit: sf probe 0; sf read 0xc0700000 0x100000 0x280000;bootm 0xc0700000
U-Boot > printenv bootcmd
bootcmd=sf probe 0; sf read 0xc0700000 0x100000 0x280000;bootm 0xc0700000
U-Boot > boot
Wrong Image Format for bootm command
ERROR: can't get kernel image!
U-Boot >
Because of a purchasing SNAFU on our side, we got the board a week late. The project isn't very long so I'm anxious to get basic Linux up and an app running on the DSP.
MW RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Michael Williamson about 14 years ago
Are you booting on an Industrial I/O (development kit) board? If so, we can walk you through installing the kernel and filesystem (do you want to run from NAND, or SD?). The process shouldn't take very long and flashing up the kernel and the root filesystem is documented on the Wiki pages.
Are you developing using the virtual box image provided? If so, the image should contain the files you need to flash up the unit.
Yes, I'm using the Industrial I/O dev kit. I'm using the virtual box image provided.
Mike, I'd love your help walking me through this. Give me a number and I'll call. If you have Skype, I'll share my screen.
I tried TFTP. First I checked that it was enabled and to see what directory it is sharing:
mitydsp@mitydsp-dev:~/tftpd$ grep -i tftp /etc/inetd.conf
#:BOOT: TFTP service is provided primarily for booting. Most sites
tftp dgram udp wait root /usr/sbin/tcpd /usr/sbin/in.tftpd /home/mitydsp/tftpd
Then, I placed the uImage file in the tftpd directory under ~mitydsp:
mitydsp@mitydsp-dev:~/projects/linux-davinci/arch/arm/boot$ cp uImage /home/mitydsp/tftpd/
mitydsp@mitydsp-dev:~/projects/linux-davinci/arch/arm/boot$ cd /home/mitydsp/tftpd/
mitydsp@mitydsp-dev:~/tftpd$ ls
u-boot-ubl.bin uImage
mitydsp@mitydsp-dev:~/tftpd$ chmod 777 uImage
mitydsp@mitydsp-dev:~/tftpd$ ls -l
total 2384
-rwxrwxrwx 1 mitydsp mitydsp 260588 2011-04-08 14:44 u-boot-ubl.bin
-rwxrwxrwx 1 mitydsp mitydsp 2177284 2012-07-23 20:04 uImage
Then I tried TFTP booting from u-Boot:
U-Boot > setenv ipaddr 192.168.2.121
U-Boot > tftp 0xC0700000 192.168.2.120:/uImage
Using device
TFTP from server 192.168.2.120; our IP address is 192.168.2.121
Filename '/uImage'.
Load address: 0xc0700000
Loading: *
TFTP error: 'Access violation' (2)
Starting again
Using device
Filename '/uImage'.
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
That's where I stand. Let me know if we can try tonight. If we cannot try tonight, I'd like to schedule a time with you tomorrow.
--Jeff
Hi Jeff,
Is your VM network adaptor set to be a "bridged" connection and not a "NAT"?. Can you ping your VM IP address frmo the MityDSP? E.g., on your VM do an "ifconfig -a" and confirm the address is 192.168.2.120 and on the MityDSP you can "ping 192.168.1.120".
Let's set up a time tomorrow, would you be willing to use Goto Meeting? We have an account and I should be able to host a meeting. This would allow me to see you setup and get you going the quickest.
I would be available to start a meeting between 7-8:30 AM and 11-3:30 PM EST.
Virtual Box is in "bridged" mode - see attached, with the following network configuration for mitydsp-dev:
mitydsp@mitydsp-dev:~/tftpd$ ifconfig -a
eth0 Link encap:Ethernet HWaddr 08:00:27:2c:be:23
inet addr:192.168.2.120 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::a00:27ff:fe2c:be23/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:625204 errors:0 dropped:0 overruns:0 frame:0
TX packets:315907 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:938776595 (938.7 MB) TX bytes:21184845 (21.1 MB)
Truncated the
lo interface results.
The MityDSP target can ping the development VM:
U-Boot > setenv ipaddr 192.168.2.121 U-Boot > ping 192.168.2.120 Using device host 192.168.2.120 is alive U-Boot >
| Virtual_Box_Network_Config_2012-07-23.png (59.8 KB) Virtual_Box_Network_Config_2012-07-23.png | VirtBox_net_config |
KF RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Keith Fletcher about 14 years ago
We also have received a batch of Mity1808 cards which have not been programmed with kernel. We are able to programme a kernel and filesystem onto these cards - so no immediate problems. However we are not sure as to what to expect their default configuration to be (The cards were purchased without development kit).
Receiving them without a kernel and file system is not too bad, but would we ever expect to receive boards without a version u-boot ?
GG RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Gregory Gluszek about 14 years ago
Hi Keith,
If you purchased the cards without a development kit then it is expected that they come only with u-boot installed. All of the cards purchased from us will have at least u-boot installed.
\Greg
HB RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Hector Bojorquez over 10 years ago
Hi everyone, I'm starting with the PROFIBUS development kit and I was trying to follow the starter guide until I came to the boot up in linux step just like Jeff
I have Enabled the serial port from VBox and configured the port mode like "HostDevice".
I got mi MityDSP hooked up with the Serial cable to my PC serial port, and plugged up, the "Power good led" is strong green, I'm in the mitydsp VM but I don't have any response.
1.- Should the target autoboot in Linux or what should I do for booting it?
2.- About the U-Boot commands that you post above, should I type them in an specific directory? //// I have type them in main terminal and I got a command not found message.
I have checked the state of the Serial port with dsmeg | grep tty in the VM, and in the host Windows machine in the Device Manager, it looked all to be OK,
3.- Should the MityDSP connection be detected on my Host machine serial devices or that is not expected? ///// Just like reference for knowing that the serial port is working properly.
I hope you can guide me in the right way, thanks!
JC RE: Starter Guide: "Boot the MityDSP-L138 up into linux." - How? - Added by Jonathan Cormier over 10 years ago
Hector, I'm going to respond in your other forum post.
https://support.criticallink.com/redmine/boards/10/topics/4825
