Building Quartus Example Projects for MitySOM-A10S
Installing Tools
  1. Run the installer for Quartus Pro 18.0 or 18.1. The components selected by default are fine. When the installer finishes, install any drivers you may be prompted about.
  2. Run the corresponding (18.0 or 18.1) installer for SoCEDS Pro. Again the default components are fine, and again install any drivers you're prompted for after the installation finishes.
    Note: On Linux, run with sudo and when prompted to launch DS-5 after the install completes, do so; this will launch the installer for DS-5.
Building the Project
First, clone the project's git repository from:
git://support.criticallink.com/home/git/mitysom-a10s.git
Then follow the instructions for building on either Windows or Linux.
Windows
  1. Open the "SoC EDS Command Shell" application.
  2. In the shell that opens, cd to the top level of the project's git repository.
  3. Change into the project directory and run make:
    cd A10S-P8-A5E-RC-SB/
    make rbf
After the build completes, the outputs can be found in: ./output_files/
Linux
  1. Execute the embedded command shell script in the Quartus install directories:
    <install_path>/embedded/embedded_command_shell.sh
  2. cd to the top level of the project's git repository.
    make rbf
