On-SoM Clock Generators¶
The MitySOM-A10S features two (2) programmable quad output clock generators, SI-B338B-B-GM up to 350MHz outputs, on the module. These are used to provide multiple input clocks to the Arria 10 SoC. It is possible to change the configuration of these clock generators by creating a custom binary image that can be loaded by UBoot. Please contact Critical Link (info@criticallink.com) for details about this process.
The generators are pre-programmed as follows:
Clock Generator (U14)¶
Bus: I2C EMAC2Address: b'1110001'
Clock Input: 25MHz +/- 30ppm (Crystal)
Voltage Level: 1.8V LVDS
| Generator Output Signals | Generator Output Pins | Net Name | Arria 10 SoC Input Balls or Other Connection | Pre-programmed Frequency |
| CLK0A | 22 | REFCLK_GXBL1C_CHT_P | U24 | Disabled - StopLow |
| CLK0B | 21 | REFCLK_GXBL1C_CHT_N | U23 | Disabled - StopLow |
| CLK1A | 18 | HPS_PLL_REF_CLK_P | D15 | 266.666666667 MHz |
| CLK1B | 17 | HPS_PLL_REF_CLK_N | E15 | 266.666666667 MHz |
| CLK2A | 14 | REFCLK_GXBL1C_CHB_N | W23 | Disabled - StopLow |
| CLK2B | 13 | REFCLK_GXBL1C_CHB_P | W24 | Disabled - StopLow |
| CLK3A | 10 | PLL_REFCLK_OUT_N | J600 12 | Disabled - StopLow |
| CLK3B | 9 | PLL_REFCLK_OUT_P | J600 14 | Disabled - StopLow |
Clock Generator (U15)¶
Bus: I2C EMAC2Address: b'1110000'
| CLK0A | 22 | REFCLK_GXBL1D_CHB_P | R24 | Disabled - StopLow |
| CLK0B | 21 | REFCLK_GXBL1D_CHB_N | R23 | Disabled - StopLow |
| CLK1A | 18 | SPARE_REF_CLK_N | AA16 | Disabled - StopLow |
| CLK1B | 17 | SPARE_REF_CLK_P | AB16 | Disabled - StopLow |
| CLK2A | 14 | EMIF_PLL_REF_CLK_N | P5 | 266.666666667 MHz |
| CLK2B | 13 | EMIF_PLL_REF_CLK_P | N5 | 266.666666667 MHz |
| CLK3A | 10 | GXB_REFCLK1_P | J4 A20 | Disabled - StopLow |
| CLK3B | 9 | GXB_REFCLK1_N | J4 A19 | Disabled - StopLow |
